Hi there'
turning ac on,there are two switch on control panel of ac.find the thermostat control this signifies the room temperature you want,set this first to a maximum setting.another switch is for the motor compressor and fun motor.rotate the switch to fun first after a couple 15 second rotate again the switch to lo cool setting w8 for 10 to 15 sec. then rotae it again to hi cool there will be a sudden heavy change of blwing air and cooling effect then rotate set the thermosat switch to temperature comfortable to your feeling,observe the cycling process,because the compressor motor stop if the room temperature reached the set up temperature.stopping or switching off just rotate the switch of the compressor motor on off position.have a nice day fix my rate thank s a lot.
