Question about Tomtom One XL GPS Receiver
REPAIR STORE Having problems whith attachment to and from car plug.
    Problem Solver:
  • 6 Answers
All i can tell you there is that they don't like cigarette lighters only accesory outlets.
Posted on May 14, 2010
My 2002 oldsmobile silhouette van ran hot now it will not start after i changed the broken hoses could anyone help me out?
Maybe you have head gaskets problem the eassy way is remube the spark plugs if you see 1or more spark plug .whith no carbon or very clean.you need the head waskets
Aug 29, 2012 | 2002 Oldsmobile Silhouette
Why would a lexus ls 400 constantly flood and not start. plugs keep getting very wet whith faul.
if you refer to spark plugs wet with fuel , 1st check for ign coil have spark , if good, then check engine compression , if under 100 psi , thats the problem.
write me mecanica03@hotmail.com
Aug 15, 2010 | 1997 Lexus LS 400
How do u do a compression test
Auto parts stores sell a compression testing tool which is a gauge and hose attachment. Remove the park plugs, make sure you mark the spark plug wires so that you can replace the wires in the correct location and keep the firing order correct. You attach the tester by screwing it into the spark plug hole and then crank the motor over several times. This has to be done for each cylinder. I recommend you get the Haynes repair manual on your vehicle so you have the proper ranges for compression for the cylinders and further instructions on doing this test.
Aug 07, 2010 | 1998 Cadillac DeVille
The starter will not engage sometimes you can jiggle the key while turning it on and it will start. Battery is fully charged
He he this is funny to me!!
You have several things going on here Ok?
Starter not engaging is one prob.
Key switch is another prob.
This all depends on the car type and year. Big question!!!
but it all is between ur key an ur starter.
So its a process of elimination to find out the real problem first.
Bad key switch, bad connections, bad grounds, bad starter solenoid,
bad starter gear, bad starter relay(depending on yr of car)
To be honest there ca be lots of different problems whith why the care will not start, so u just have to start with elimination of 1 thing at a time.
At most autopart stores they have repair books for just about every make an model of car an trucks !! Try that if confused!!!
Jul 20, 2010 | 2001 Daewoo Lanos
The locks door don't work is a problem whith the fuse or relay . cadillac sedan deville 1991
If none of the 4 doors work check the relay for no fuse runs it. It is attached to a breaker although that breaker runs to the windows as well
May 22, 2010 | 1991 Cadillac DeVille
Where do i find the spark plugs in my car to replace.where can i find a repair manual. thanks
ordera repair manual on line or check the local parts store or Jag dealer if you want to spend some exdtra money. to find the plugs follow the plug wires from the coils down to them. you may find that if the quarters are very tight and you dont have all the necessary attachments for your sockets it might be easier to have someone else do it. most cars these days can easily make it to 60,000- 100,000 miles before they need plugs so if its not running right and its lower mileage i might look for another cause for the problem.
May 17, 2010 | 2000 Jaguar S-Type
My toshiba satellite a205-5804 has a problem with the main board, when its plug in it freezes but when not , when is used whith the battery it works alright. a repair center told me is the main board, but...
Are you using the original charger or a universal replacement? As loose fitting power plug can cause this problem but so can a loose connection at the power jack (repairable) or a cracked trace on the main board from stress at the power jack (not usually repairable - ie needs a new board). JC
Nov 17, 2009 | Toshiba Satellite A135-S2276 Notebook
The two center spark plugs are dead on a 1992 stealth
sounds like a bad ground or a bad connection someplace.
Mar 08, 2009 | 1992 Mitsubishi 3000GT
Problem whith the screen
This problem is either the LVDS plug that plugs into the lcd display, or the logic panel, or worse case scenario the lcd display is bad.
Feb 03, 2009 | Vizio GV42L 42 in. LCD Television
Usb driver for samsung U600
i don't know if there is a site where you can download some software. but this problem happened whith my samsung u600, all i done to fix it was to unplug my mobile phone from my laptop and then plug it in again.
Jan 09, 2009 | Samsung SGH-U600 Cellular Phone
Tomtom One XL GPS Receiver Logo
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
