Question about Siemens SpeedStream Modem (4100) (SS4100)
Looking for the isp address
How do i find the isp address so i can link my modem to my computer
  • 39 Answers
Go to this site http://whatismyip.com it will automatically show your IP address. Hope this helps.
Posted on May 14, 2010
No light only power light is on...
First, did you pay the bill? Unplug the IPS modem, remove battery, if applicable, unplug TP Link, shut down computer. Ckeck ALL cables reseat, Replace battery, plug in ISP modem, allow it to selftest, plug in TP Link, allow it to selftest, Reboot computer. If you connect ISP Modem directly to PC and it doesn't ID your IP address use this: http://helpdeskgeek.com/networking/release-and-renew-an-ip-address/ To assist you. If this doesn't work contact your ISP provider . Try another Wireless Access Point. My ISP, Xfinity, drops from time to time , for no appearent reason, due to a number of outside difficulties.
Dec 14, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Bought 2nd hand modem to have 2 feeds off the same broad band i alredy have anambit modem, but was hoping to use one for games , the other for pc. i tried to set up modem but although all leds showing...
You can't have two separate modems because of addressing conflicts with your service provider. You can connect one modem only. What you need is a router to allow multiple computers to share the connection. The router presents a single address to your ISP, and assigns its own addresses to the computers you connect.
Visit the site of any router company and they'll have information on setting up your own home network. It's usually a pretty simple process.
Feb 18, 2010 | Arris SURFboard SB4200 Modem
Internet connection fails through DLink router
Some ISPs (Internet Service Providers) require that you "register" the 'MAC' (not an Apple --> Media Acquisition Control) address of the network-adapter of your computer (or router) with the ISP,
before the ISP will allow your computer (or router) to be provisioned.
Your router has a different MAC-address than your computer.
So, your computer works with its "registered" MAC-address,
but your router cannot connect with its "unregistered" MAC-address.
Access the web-server inside the router, and click the 'Clone MAC-address' button, and restart the router.
Then, the router will send the MAC-address of your computer, rather than its own MAC-address, to your ISP.
Dec 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
ADSL modem connects to my isp but I cannot get internet access from my PC when the modem is connected. I have manually assigned IP addresses and entered my IPS DSN addresses and I still cannot get any...
Contact your ISP -- they may need to "authorize" your computer, by extracting the MAC (Media Acquisition Control) address of your network-adapter from your computer, and having the ISP add the MAC-address into their database.
Other than that, your ISP should be contacted, and they should provide "technical support" to you, as their customer -- if they want to KEEP you as their customer.
Dec 30, 2009 | Computers & Internet
Connecting modem to WAN port then any lan port to computer provides no connection. straight from modem to comp is ok.
Make sure comp lan and wan are both activated, Make sure the ethernet cable from modem is plugged into the input slot and NOT 1,2,3,or 4
Then after all is connected, unplug main modem for 10 seconds, plug back in, then do the same with wireless router. 5 minutes later, you should be good to go.
You can access the software of you router by opening up an internet page, and type 192.168.1.1 and hit enter. It should bring you right straight to the router's firmware/software where you can change any settings if desired.
If it asks for username and password, the default is usually admin for both. (see owners manual to be exact)
Nov 16, 2009 | D-Link AirPlus DI-524 Wireless Router
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Connecting 2 computer thru DI-514
Well I believe wat ya need to do is simply obtain a NEW "Account" with NEW Logon & Password with a NEW Internet Service Provider. Then you set up the modem to connect to the new ISP, at the NEW ISP's address, with the NEW Password & Logon. When you got the modem ya should have got a "Setup" CD that should walk ya thru the connection routine... Below is a link for a "Users Manual" that should help you get connected. ftp://ftp.dlink.de/di/di-514/documentation/DI-514_qig_en_Quick-Install.pdf
Aug 15, 2007 | D-Link DI 514 Wireless Router (DI-514)
Siemens SpeedStream Modem (4100) (SS4100) Logo
252 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
