Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
The stop/cancel light keeps flashing. I have tried Heated dry to Normal sequence buttons and I have tried Heated dry to High temp wash sequence. When I have pushed soak and scour the stop/cancel light stops and the Pot/pan and Normal wash lights start blinking
  • 1 more comment
  • puttinito819 May 14, 2010
    I don't have the tech sheet and this problem stated at the end of the cycle and I have been running the hot water before starting.
    The machine is draining because I put a gallon of water in the bottom and it drained....I NEED HELP ASAP BECAUSE I HAVE A HOUSE FULL OF GUESTS COMING THIS WEEKEND.!!!!
  • puttinito819 May 18, 2010
    The stop/cancel light keeps flashing. I have tried Heated dry to Normal sequence buttons and I have tried Heated dry to High temp wash sequence. When I have pushed soak and scour the stop/cancel light stops and the Pot/pan and Normal wash lights start blinking More
    Comments:
    May 14, 2010
    - I don't have the tech sheet and this problem stated at the end of the cycle and I have been running the hot water before starting.
    See less
    I can not find the wiring diagram is missing from the inside of bottom kick plate area.
    So I can not determine the sequence or reason certain lights flash when I try to reset per suggestions
  • Whirlpool Master
  • 3,247 Answers
Unfortunately I cannot view the comments from other fixya.com consultants so I am coming in cold on this one.
But it appears you are trying to isolate the problem of why the stop/ cancel light are flashing. I suppose the only solution offered in the user guide is to contact the whirlpool service.
Have you considered if the dishwasher is level and fully secured to the underside of the counter. The door switch needs to be fully engaged (both live and neutral switches) otherwise this model is known to cause faults.
Wiring diagram is shown above. Not sure how good it is.
YOu can download the service manual from http://www.AllRepairManuals.com/ for $4.95 which has all the details.
Posted on May 18, 2010
  • 3 more comments
  • Sam May 20, 2010
    hi, please let me know if you are making any progress on your problem. would appreciate if you rate the solution if your satisfied. otherwise let me know if there is any thing that you want to find out further.
    cmmiuser01
  • puttinito819 May 20, 2010
    The dishwasher is level.
    The door latch engages.
    I downloaded the wiring diagram.
    I have tried all the combination's of button sequences.
    Normal...Heated dry....Normal heated dry
    sani scrub ....heated dry...sani scrub heated dry....
    and several others....
    I have unplugged and plugged it back in.
    I have take off the water drain on the bottom of the take by taking the machine out
    and turning it at a 45 degree angle..another person's idea.
    I purchased and downloaded the manual.
    I have also done the hot water thing...I have always done this since I bought the machine.
    There has been on ONE time that the whole panel lite up and I tried pushing power wash start and nothing happened.
    The stop /cancel light keeps flashing when door is open or closed.
    I assume the button sequence combination are done with the power on and the door closed.
    I did try a couple time with the door open.
    I am out of work and can not afford a new dishwasher or high repair bill.
  • Sam May 21, 2010
    sorry to hear that you are still having the flashing light problem with your dishwasher.
    Unfortunately, I am not able to find any documentation that specifically highlights the problem you are having. The flashing of stop/ cancel LED is not documented anywhere by Whirlpool. There is a specific mention of the Clean LED flashing in many places (linked to heater failure) but not this one.
    I do not have access to your model and cannot provide any concrete suggestion. However, I am leaning towards a few possibilities but first your last question. The diagnostic routine for the dishwasher is to be done with door closed. This is mentioned in the Repair manual that I had pointed you to in my previous comments.
    1. Normally with the dishwashers there is a flood switch under the base. This is kept to make sure water does not collect in the there (leaks etc) and damage the heater and motor. So if water has leaked from under the door gasket the flood switch is tripped and shuts the dishwasher. But I am not able to find any circuit diagram for your model which shows the flood switch. In any case I noticed from your description that the unit still operates in some cycles like drain. So the flashing light is unlikely the cause of a flood switch trip (if it does exist).
    2. The other possibility is the Float switch. I am assuming you know where it is on the base of your dishwasher. If the float switch is blocked, ie, the switch inside is not sensing properly it might assume the dishwasher is always full and that will prevent the wash to start.
    Do have a digital display on your model? if so, what number is displayed on it when the light is flashing?
  • puttinito819 May 21, 2010
    No I do not have a digital display.
    I have put in a service request with Whirlpool and a tech is to come
    sometime Monday.
    If you would like I will email you what the outcome is from the service call.
    ? If the motor was burned out would it still drain? Because it has drained when I have added water manually to check to make sure float was working over a week ago.
    It does drain but there was one day my daughter closed the door and the motor ran
    for hours on empty with the stop/cancel light flashing.
  • Sam May 21, 2010
    The dishwasher has a separate drain motor and wash motor.
  • Whirlpool Master
  • 12,061 Answers
Http://www.devicemanuals.com/guide/Home%20Appliance/Whirlpool/Whirlpool-DU1100XTP-dishwasher-User's-Guide-TWpnM05qUT.html
http://frigidaireservicetips.com/pdfs/486_5.pdf
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Ok please find above service manuals, and a user manual too, for your generic unit, please use theses to troubleshoot and hopefully repair. These manual are what engineers use, to troubleshoot and repair these items.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
Below is a FIX, that works all to often regardless of why, it often works, so if all else fails give it a go...
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Posted on May 14, 2010
    Thank you. I figured it was something in the drain system. I will in the morning take the DW out and drain the flood reservoir. It kind of makes sense because I think the dishwasher couldn't drain properly because the disposal drain was clogged. I was not here.
    I usually don't open the door during mid cycle...so I don't think that is the issue plus no one was here.
    I will let you know how the reservoir drain works. I do know that it is draining properly now into the garbage disposal. I even checked the air vent that comes up on the sink.
    so I am going to shut things off at the breaker.....pull out the DW and drain the excess water...I will look at the parts manual to see where it is and to make sure I do the 45 degree angle on the correct side...I would assume the right hand side.
    should I try the re-set program again after?
    I have done everything. I took the drain hose off and emptied out all the water.
    I have tried the button sequences. Sometimes the other lights will come on and stay flashing
    like the Pot n Pan wash & Normal wash flashes.
    Is there another sequence? Because I can't find the receipt Whirlpool is saying it was built in Dec 07 but I actually bought it Nov. 09.
    Any suggestion would HELP!!!
    President:
  • 1,382 Answers
Hit the keys in this order:
high-temp---> heat-dry---> high-temp----> heat-dry What this does is it will put the unit in a diagnostic mode. It may take a minute or two but should clear everything. If not, try again. Any power interruption while the dishwasher is heating or drying, can throw it off. The manufacturer will not tell you this but will insist on coming to your home and charging you a big fee. Hope this helps you!
Thank you
  • 3 more comments
  • Prakash R May 14, 2010
    The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
    To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
    Courtesy:jsrock516
    Thank you. But I have tried this several times now. It is opposite from another solution I found on the web site. I unplugged the DW and tried again and nothing happened.
    I have done this with the door open and the door closed.
    Sometimes when I push soak scour and the normal button the normal button flashes and the stop cancel button still flashes....I thought maybe it was the pump drain part so I put a gallon of water in the bottom and it did for a short time drain....I am so frustrated....Whirlpool is not honoring the warranty because I can't find the receipt. So they claim I purchased it in 12/07 when I bought it in 11/09.....
    Now I have a dishwasher full and 2 sinks full of dishes and company coming for the weekend.
    If this fix ya can't help with the code because I don't have the diagram or sequence that is supposed to be in the bottom panel.
    Any other suggestions will be appreciated.
    Thanks
    Dennis
    This is ironic because I replaced a Kenmore DW that was 12 years old after replacing the cicuit board and the tech said is was a sensor in the door and it would cost $400+ and would be better to buy a new one so I did and now 6 months later I have a circuit problem with a new Whirlpool DW....HELP!!
    As soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10 ohms).Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
    Or else If it plugs in under the sink unplug it and let it stay that way for 5-10 mins and see if that changes anything. If it is hard-wired see if you can figure out which breaker it is on and turn it off for same amount of time.
    I have unplugged it several times and tried the sequence with power and without power and with the door open and the door closed.
    It never gets to a point that the water fills.....I have not turned off the circuit breaker will try that next...only unplugged and plugged back in with 12 hour waits to 10 min waits before plugging back in.
    It is a circuit or programing problem....Again I don't have the sheet that is suppose to be on the bottom panel....I put water in the bottom just to see if if would drain and that the pump was working and when I did get it to drain.....some how...it did drain....about a week ago the garbage disposal drain pipe was clogged it it clear now ...would that cause a circuit/program default??
    Thanks for responding.
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light keeps flashing, and we cant cancel the program or get it to wash
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Control clean light keeps blinking and dishwasher will not function
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Light flahing
will have to repair the circuit board as something is faulty in the board.
it will not be too costly as the lights are flashing and that means only something is short.
thanks.
Sep 21, 2008 | Kenmore 13732 / 13734 / 13739 Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
151 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
