Question about Linksys WRH54G Wireless Router
I'm using a WRH54G router and a desktop with wireless adapter WMP54G. My computer was using this for a year now and i reformat. upon installation of the drivers for my mboard, vcard, I installed the driver ffor WMP54G then it rebooted, i usually see a green icon in the system tray to look for wifi but its not appearing, do i need to install the cd for WRH54G but my problem is I dont have that cd.
  • 173 Answers
SOURCE: "WPC54G is not installed"
Hai rob if ur device manager says error code 10then it seems the drivers are not installed properly for the adapter, try to update drivers, go to device manager, right clich adapter and click update driver and try to update driver, in some case ur pc may require win 2000 cd to.. check for the instructions while installing it , that would surely fix your problem..
Posted on Nov 14, 2007
  • 51 Answers
SOURCE: installation broadband router linksys WRT54G v5
Please connect the laptop to the linksys router with the cable provided. On the linksys, connect the able in any port from 1-4. Please do not connect the laptop to the Internet port.
From the start menu, select Run. Type in cmd and press enter. At the prompt, type in ipconfig. On the line that says Default Gateway -> this is the address of the router when connected to the computer and (DHCP being on).
Make a note of the Default Gateway and type it in the address bar in an Internet Explorer window. At the login prompt, leave the username prompt blank and type admin for password.
This will allow you to access the web GUI.
Hope this helps :) Kindly leave a good feedback. Thanks...
Posted on Nov 27, 2007
Nick Spirov
  • 35 Answers
SOURCE: cannot connect my wifi laptop to the wireless router
If you use your original Win XP disks, there's a chance you now have XP SP1 (Service Pack 1). Make sure you've made all the necessary Windows Updates as working with WiFi networks was enhanced with XP SP2. Then you can try to find your wireless network and connect to it. If you had a secured network you'll need your previous network key (similar to a password, but without a username, the wireless key is needed to exchange data with the router) If you can't remember the settings on your Linksys you can reset it to factory settings with inserting something into the reset hole to press the hidden buton and holding it for several seconds until lights on the front flash. Then you HAVE to run the initial install procedure (find your CD and Quick Start sheet) because your router will be open and unsecured.
Posted on Jan 12, 2008
In your internet explorer address bar, type in the ip address of 192.168.1.1 and see if it asks you for a password.
If that isn't it, try 192.168.1.245.
The default password is admin. No username.
Also, go to www.linksys.com and they have free chat support and can walk you through this issue.
Posted on Apr 30, 2008
How to install linksys wrh54g
Welcome to FixYa! To install Linksys WRH54G, here is a manual that you can use, just click the link and it should bring you to the answer page. http://downloads.linksysbycisco.com/downloads/wrk54g-ug_web.pdf
Hope this helps! Thank you for using FixYa!
Jul 07, 2011 | Linksys WRH54G Wireless Router
We have had trouble free operation of our LinkSys Wireless Router and the WMP54G wireless G PCI Adapter. However, recently, we have found that the HP Pavillion computer will start to cycle off and...
Try booting into safe mode, and disabling the power management for the wireless adaptor (in windows, control panel, system, device manager, then click the plus sign on "network devices" and select the wireless device by right clicking it and selecting the "properties"...one of the tabs will have a setting on the page for power management- (you do NOT want to allow the device to shut itself off).
For a better solution, you'll need to post your OS.
By the way, it might not be the PCI card, but rather your OS, or some hard ware problem (such as RAM or Power Supply failing with the drain from the wireless antenna). Let's start with your OS and rebooting into "safe mode + networking" (hit "f8" while rebooting) once you've turned OFF power management for the wireless PCI device.
Sep 05, 2010 | Linksys Wireless-G WMP54G 802.11g/b
Just installed a Netgear Wireless-N 150 router and my other desktop - which has a Linksys Wireless-G PCI adapter (model WMP54G) continually toggels between Acquiring Network Address and Not Connected. Are...
if your useing a G network (the router is a G?) then the adapter will attempt to connect via N you have to tell the adapter to connect via G mode only, it cut the speed in half but it should work.
if you have an N router check to make sure the router will accept an N connection. via the network configuration page. depending on the router that may be at http://192.168.1.1 or http://192.168.1.255
Jun 10, 2010 | Linksys Wireless-G WMP54G 802.11g/b
Doesnt work on my msi
www.opendrivers.com/driver/.../linksys-wmp54g-v4-wireless-g-pci-adapter-driver-2.2.7.0-free-download.html
#3 question : network controller questionmark indicates it didnt find the driver it was looking for and shut it down.
Check this site for your driver
Apr 27, 2009 | Computers & Internet
Password doesn't accept
Try just using admin in the password....leave the username blank.
Apr 08, 2009 | Linksys WRH54G Wireless Router
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless-g wmp54g cannot access internet
Hii
Solution- For windows XP
#1--On your computer in the right lower corner you will a green icon for linksys adaptor --
Right click on linksys icon- select option "use windows wireless configurastion --- Select Yes ---
Green box turn Grey --
#2-- Start - Control Panel-Network Connections ---
Rigfht Click on wireless network connection- Selct View Available wireless network - Here you can see your network --
Mar 29, 2009 | Linksys Wireless-G WMP54G 802.11g/b
I have a linksys PCI card WMP54G. Worked fine for 1 year now it will not connect. Other wireless computers still get stong signal from router. Checking control panel "wireless connection 7 Not connected,...
This is something to try:
Download drivers for your wireless device from this website. Afterward uninstall your wireless adapter. Then re-install it using the drivers you just downloaded. That should repair the issue(s), if not let me know and we'll take a look at other possibilities.
Mar 15, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys WRH54G Wireless Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
