Question about Canon MultiPASS MP390 All-In-One InkJet Printer
COMO CAMBIAR LOS CARTUCHOS DE TINTA
COMO LOS Cambiar Cartuchos de Tinta
MUKHTAR
  • 2022 Answers
SOURCE: acabo de cambiar los cartuchos
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons
Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on,
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
pagebor
  • 2785 Answers
SOURCE: tinta
plz post in english
Posted on Sep 02, 2008
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
Tinteiros
  • 85 Answers
SOURCE: me da un error 5C00
Ola!
Si usted tiene que el muchos error brillante enciende o los problemas eléctricos entonces es probable que sea eléctrico.
¿Sin embargo, si gusta la mayoría... y su copiadora simplemente ha quedado sin usar durante algún tiempo?
¿Entonces con tal de que funcionó OK antes de un período de non-uso? Usted apenas necesita usar un IMPRESIóN CABEZA LIMPIEZA EQUIPO para desatascar los motores de reacción diminutos.
¡Un Equipo de Rubor Chorro de tinta Mágico normalmente trabaja un obsequio en aquéllos!
La Magica es ideal para el unclogging los motores de reacción diminutos en cualquier Canon, Epson HP y quitando esas líneas blancas horribles que normalmente aparecen en las impresiones cuando secó la tinta estorba varios motores de reacción...
¿Así si el suyo aparece una traba para ser? todos que usted debe necesitar hacer son usar el equipo de Rubor Chorro de tinta Mágico para empapar la cabeza de la impresión y usted debe estar imprimiendo de nuevo gusta nuevo.
Usted se cubre atrás por un 30 dinero del día la garantía si no.
¡La Suerte buena!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Posted on Sep 12, 2009
  • 304 Answers
SOURCE: como remover y poner los
Segun el modelo Mantener el boton pulsado hasta que el carro se visualice y puedas remover los cartuchos.
Posted on Jul 01, 2011
ES IMPRESORA Y SCANNER. NO PUEDO USARLA SOLO COMO SCANNER AUNQUE NO TENGA TINTA????
Muchos de los lectores tienen una funci?n de copia que utiliza la impresora . Usted puede ser capaz de comprar cartuchos de tinta para que o tal vez rellenado de los cartuchos de tinta si el coste es un problema. Creo que ser?a necesario de tinta para poder utilizar el esc?ner debido a la funci?n de copia.
Dec 31, 2014 | Office Equipment & Supplies
Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
Feb 24, 2012 | Office Equipment & Supplies
Como remover y poner los cartuchos de tinta de una impresora hp
Jul 01, 2011 | Office Equipment & Supplies
Impresora bloqueada y no detecta cartuchos de tinta
Trate de limpiar los inyectores de los cartuchos. Si estás utilizando Windows, vaya a Todos los programas o Programas y, a continuación, seleccione la carpeta de programa de la impresora de la> lista de la carpeta de la impresora, haga clic en Mantenimiento - Alinear cartuchos> haga clic en Imprimir> Siga las instrucciones en la pantalla del ordenador hasta el final.
Si está utilizando Macintosh, desde el escritorio del Finder, haga doble clic en la carpeta de la impresora> haga doble clic en el icono de la utilidad de la impresora> En la ficha Mantenimiento, haga clic en Limpiar inyectores de impresión. Una página se imprime, la tinta pase por los inyectores del cartucho de impresión para limpiarlos. Imprimir el documento para comprobar que la calidad de impresión ha mejorado.
Nota: Esto se traduce utilizando translate.google.com.
Jun 18, 2011 | Lexmark X2600 InkJet Printer
Deseo saber si el cartucho se puede recargar ?y cuantas veces?porfavor........
Los consumidores pueden rellenar cartuchos de tinta s? mismos con un juego, o ellos pueden tomar el cartucho a un refiller o el remanufacturer donde tinta es bombeada atr?s en el cartucho. Los informes del Mundo de computadora personal que rellenaron cartuchos tienen porcentajes de aver?as m?s altos, la impresi?n menos p?ginas que nuevos cartuchos, y demuestran m?s problemas de en-p?gina como pasar como un rayo, rizar, y el color sangran
Jan 14, 2011 | Office Equipment & Supplies
HP C7280 All in One Printer: Ongoing error to change ink
Hola. Si el cartucho es nuevo, devuelvelo, es el cartucho que esta defectuoso.
Pero si es cartucho ha sido recargado lee las siguientes lineas:
Tienes que decirme si los cartuchos was refilled, porque en ese caso la impresora no los va a reconocer como llenos., la razon es porque los cartuchos tienen un "contador electronic" que solo analiza informacion de cuantas hojas se han impreso, y al momento de ser recargados solo les colocan tinta, y el contador sigue marcando vacio.
Si aun con este mensaje puedes seguir imprimiendo, no te preocupes, pero si no, por favor dejame saber el modelo de tus cartuchos como respuesta y te mostrare como resetear.
Apr 04, 2010 | HP PSC 2175 All-In-One InkJet Printer
LEXMARK X3550
Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
Aug 19, 2008 | Lexmark X3550 All-In-One Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
221 people viewed this question
old marine
old marine
