I have a Samsung LN-4061F with a TiVo HI Def DVR. When viewing HD programming the picture becomes choppy during action scenes. For example, during sporting events when the picture pans with the action, the image becomes rough and choppy. Is this normal? Jason
If your using a set top cable or satelite box then it is an issue with your HD service. Call them . They may need to swap out the box and check the signal. If you have no box then you may wana boost or/and filter your signal. You can purchase a signal amplifier online or at any radio shack or best buy. You may want to ask SAMSUNG if there is a firm ware upgrade for your TV.
Posted on Mar 29, 2008
Hooking up laptop to hdtv with hdmi cable
Only if your graphics card can handle HD viewing
Jan 03, 2009 | Tivo Series2 TCD649080 Video Recorder
I'm getting cable channels but no high def
Your TiVo is only recording basic cable (i.e., channels it can receive without a cable box). You will need a digital cable box from your cable company to record channels above 99. If your TiVo is a Series 2 you will not be able to actually record in HD either. You should be able to record the HD channels from the cable box, but they will not be HD quality. (This is my current setup and while the picture quality is much better than basic cable, it pales compared to bypassing the TiVo and watching HD directly off the cable box to the TV.)
Dec 23, 2008 | Tivo Series2 TCD649080 Video Recorder
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
OK, I had Dish network come out and install DVR HD. Had pixel des torsion viewing everything I recorded. They came out 3 time and replace DVR and check everything 3 time with no improvement. I had them remove everything.
I called Direct tv and they did the same thing. installed there dish and cables and DVR. Same problems. My question is? Is this the nature of this equipment or is there something they are missing.
Jul 11, 2008 | Tivo Series2 TCD649080 Video Recorder
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
May 18, 2008 | Samsung TV Remote Control
Picture Size problem with Samsung Flat panel LN-T3253H
You should contact Samsung service to know if the internal setup for the picture sizing was not adjusted properly at the factory.
Take care that some of these sets have a user zoom mode. Maybe it is in the zoom mode. Check in your instruction manual before calling for service support.
Jerry G.
Apr 12, 2008 | Samsung LN-T3253H 32 in. LCD Television
Blotchy picture
I get this too with my Samsung. Are you watching HD content or standard (cable, satellite) tv? If it's the latter, that's why. The lack of quality really shows on analog signals. The shows that I Tivo look horrible a lot of times. Another thing is the connection to the television. If you are using standard RCA connectors, try switching to either component or HDMI.
Hope this helps.
Feb 01, 2008 | Samsung DLP HL-P5663W 56" TV
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
