Question about Whirlpool Dryers
I have a two year old Whirlpool gas dryer. It will start out running warm then the heat stops. Whirlpool told me to replace the fuse...I did...and it is still doing it. Any ideas? There is no obstruction in the air passage and free of lint.....and I am mechanically challenged. Can you point me in a better direction than Whirlpool?
  • Whirlpool Master
  • 8,220 Answers
These coils tend to work then get hot and quitI have a two year old Whirlpool gas dryer.  It - abe36dd.jpgwith age.
Replf79d4c7.jpgace em
Posted on May 14, 2010
Whirlpool front load dryer will not start
Does your dryer have a reset switch on the back, usually a small red button, if it does press this and ten test dryer starts again.
Dec 21, 2012 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
Stopped heating. Had service repair yesterday and he replaced the ignitor. Does not heat again, even though it warmed up briefly after the repairman completed the job. What else could the problem be?
Hello- Have him come back out (AT NO CHARGE) and check the gas valve coils these are probably not opening the valve, thus letting the gas out. It is a common issue and sometimes we, the Techs, need to sit there and watch the ignitor light the gas for a whole cycle. Often it will heat for 30 minutes and then the coils will stop opening the valve when told to by the timer. It is possible that there is a thermostat issue but less likely. Hope this helps, best regards.
Sep 27, 2010 | Amana ALG331RAW Gas Dryer
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
I have a whirlpool gas dryer, 4 years old. i
It sounds like the heating filament below the drum has either fried one of the fuses down there, or has some lint or something fallen on to it.
Did you notice if the drum still heated up? If it did, then its a bit trickier to completely ID what went wrong. If it no longer heats up now, then the thermal cut-off fuse has been blown and will need to be replaced (most common problem with a dryer)
Typically, once it is unplugged, you can open up the panel below the door (there are normally a couple of latches along the top gap that you need to push in with a couple of screwdrivers to open). Once open, you should see a heating coil that provides the hot air to the drum, look to see if there is anything in contact with the coil. If there is something there, remove it. If not, then continue below.
Now, if your dryer has stopped heating up, you need to pull the coil and replace the thermal cut-off fuse (or get someone in to do it for you). If it was still heating up, you can start the dryer with the panel open (make sure everyone and everything is well clear of the opening) and see where it is smoking from.
Nov 01, 2009 | Whirlpool GGW9868K Gas Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Nov 27, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
