Question about GPS
Megellan was working fine. turned it off to go into resturant. came out it will not turn back on
  • jrickme May 14, 2010
    thank you for help. IS there more Ican do with button besides taking it somewhere?
  • 4,369 Answers
Not sure if this will help with Magellan, but my Mio would not start after I discharged the battery.
I had to recharge and then hold down the on button for 30 seconds to reboot it and then the screen came on.
Posted on May 14, 2010
    thanks for the help. I plugged it up and pressed the button, held it and pressed it some more and it came on. Then I had a hard time getting it to turn back off. Sounds like something happemed to the button doesnt it.
  • gerry bissi May 16, 2010
    if it has screws holding the back cover on, you can carefully remove the cover and see if you can see what's causing the button to stick or bind.
How turn on Megellan GPS device
If it doesn't turn on with the normal on/off button, there is also a reset slide button on the side(sometimes under a rubber cover), slide it off and then back. Should reset and on/off switch will work.
Nov 11, 2016 | Magellan GPS
Restart gps magellan
Hello
Check the condition of the battery of your Megellan GPS. Most Megellan GPS batteries will last not more that 40 minutes of continous use after full recharge. Ig battery power is found OK, the firmware of your GPS has the trouble. You ahve to contact nearest Megellan GPS authorised service center to set it right. OK.
Dec 15, 2011 | GPS
When I turn on the key,it lights up everything but it want engage the starter.new battery, new starter and nothing happens.I've tried park and neutral and nothing works.the car was working fine and I...
A vette huh? Veettes are a trick because of the glass. It's very important to have good grounding contact.. Just a chrck list;
Battery is up to par
;Battery ground cable is clean,clen on the engine and battery
Battery positive cable clean, clean and good connection at starter and battewry?
Remove and reinstall the battery negative cable at the battery
Do your headlights work? If so we can do another test.Let me know
Sep 17, 2009 | Chevrolet Corvette Cars & Trucks
Lg vu water damage
Let it dry completely without the battery and it may come back to life. If a red mark appears on the cell then it is ruined and will have to be replaced.
Jul 06, 2009 | LG Vu CU920 Cellular Phone
When I turn my Megellan Maestro it says FAILED TO WRITE TOC
Yes, there is a reset button. It is on the side. Look for the word "reset". You may need a magnifying glass.
May 13, 2009 | Magellan Maestro 3200 GPS
Blower stoped working
sounds like a blower motor resister
Jan 24, 2009 | 2005 Chrysler Town & Country
Megellan RoadMate 300
You can find it here: http://magellan.cachefly.net/manuals/MRM_300na_en.pdf
You may also want to know that there is a MAJOR firmware update avaiable for your device.. It looks like it would make your GPS a lot faster and more accurate. You may want to take care of that update too while you're working on your device. The update can be found here: http://www.magellangps.com/support/notes.asp?supportID=288
Let me know if that helps!
Regards,
Steve
Sep 01, 2008 | Magellan RoadMate 300 GPS Receiver
Megellan 3000T - went blank
Being solid stae electronics - there is little or nothing for you to do
With this type of thing it works or it does not.
Mar 17, 2008 | Magellan RoadMate 3000T GPS Receiver
GPS Logo
18 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
