Question about Salton JVPM1W Coffee Maker
I have a juan valdez pod coffee maker and the latch broke that holds down the top .I need to know where yo get this part
When i turn machine on and put the capsule in i press the start button and the water leak out the bottom instead of the spout
Turn the machine off with the Power button, and pump the pod receptacle latch on top 3-5 times. Turn machine back on. Ta-Da!
Jun 01, 2011 | Nespresso Essenza C100 Espresso...
One pin broke off on the back of the plastic top to my DGB 300BK Grind and Brew and after several temporary fixes, I need to find a new top. The grinding cycle still works if I hold the top just right,...
Kathleen,
I just called Cuisinart Consumer Service Center at 1-800-726-0190 and the representative I got (Christina) placed an order for the part and had it shipped to me. I didn't have to pay anything! It should be here in 7-10 days. Guess I'll be doing Starbucks until then, but a small price to pay overall for my favorite coffee maker.
Jun 01, 2011 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
Coffee won't pass through pod
the K-cup is punctured at the top and at the bottom.
you can take a corkscrew, and puncture a number of holes in the bottom of the K-Cup... verify there is a hole at the top... just before you start to brew... press down on the black arm over the cup... but not too hard...Lets see what happens... if it all looks good... no problems... then we need to either adjust the arm... or shim the k-Cup up a little bit...
you may also check the rubber Seal around the top pin that punctures the K-cup...
sounds like you lost your rubber seal around the top of the K-cup...
you can re-phrase after looking and testing....
Apr 28, 2010 | Keurig B60 Coffee Maker
Broken coffee mill/container on Cook's Essentials CEMB10TC
This is the same part as on the Melitta Mill and Brew, notorious for the same problem. They are no longer being made; you can't get the replacement part in any of the "official" channels. Somebody somewhere may have old stock. You always had to replace the entire lid, not just the latch. Most people figured out to use a mall weight to sit on top of the lid so it will work, or just hold it down with your hand until it finishes grinding.  Not a great solution, I know. Sorry. I'm in the same boat!
Dec 24, 2008 | Cook's Essentials CEMB10TC
Latch will not snap closed
Had the same problem.I fixed it by carefully prying the top lid apart,the latch had become detached from the slider inside.Simply snap the latch back onto the slider and snap lid assembly back together.Do all this unplugged with reservoir empty.
Dec 10, 2007 | Philips Senseo HD7832 Coffee Maker
Broken latch on coffee grind lid
I have drilled a small hole where the latch was and put a screw in. The screw serves as a latch and has worked fine for years.
Aug 10, 2007 | Cook's Essentials CEMB10TC
Coffee Makers & Espresso Machines Logo
3,828 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Anthony Turner
Level 1 Expert
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
