Question about Goodman GMS90703BXA Heater
Goodman Furnace Hi, I have a Goodman Furnace which was installed new in 2005 and now, I notice the burners (6) keeps on cycle on and off while it is running (the flame could not stay on steady or light-off). I discovered that the exhaust blower has some condensate collected the blower chamber so I had to take the blower out and empty the condensate and I also check the two drainage lines to make sure there is no blockage(one drain line connected to the exhaust PVC line and the other drain line is connected to the bottom pan). After empty the condensate (about 4 ounces) from the exhaust blower, and putting the blower back, the furnace then works fine. Do you have any suggestion as to why condensate is collected in the exhaust blower and could it be any other problem(s) that I should look in to? Any advice or suggestion will be appreciated. Thanks. Tom. Please email to DEMIPHAM@YAHOO.COM. Thanks, Tom
  • Dal440 May 12, 2008
    My Goodman furnace will cycle on and all burners will fire up. The blower functions, but the burners only stay lit for about 15 seconds. There is no obstruction to the blower. Any idea what is causing the unit to shut down the burners?
  • bdgrbb Oct 27, 2008
    I HAVE A UNIT THAT WAS INSTALLED IN 2003. LAST DECEMBER 2007 THE FLAMES WOULD TURN ON AND TURN OFF BUT WOULD NEVER STAY ON. I CALLED THE COMANY THAT INSTALLED AND TURNED OUT THAT THE UNIT WAS RUSTED AND DAMAGED THE THERMOSTAT ACCORDING TO THE TECHNICIAN. THE PIPE THAT COMES OUT OF THE UNIT IN FRONT HAD A LOT OF CONDENSATION THAT I REPORTED A YEAR LATER AND THEY CAME OUT AND WRAPPED SOME INSULATION AROUND IT. I SUPPOSE THAT IS WHAT DAMAGED THE THERMOSTAT. NOW MY UNIT LEAKS WATER UNDERNEATH AND I CALLED A DIFFERENT COMPANY TO COME OUT AND THEY SAID THE UNIT WAS INSTALLED INCORRECTLY. THE UNIT SHOULD HAVE HAD SOME TILT TO THE FRONT TO ALLOW THE WATER TO DRAIN PROPERLY. AS A RESULT THE IT WAS CLOGGED.
  • 1,420 Answers
Inspect the venting system for sags or blockages. The added restriction could be adding to your issue.
Posted on Mar 31, 2008
  • Chandler Ede
    Chandler Ede May 16, 2008
    Also clean out the condensate lines that go to the drain from the blower. there should be no water in the blower.
Goodman gmh95 furnace wont ignite
try the pressure switch you may be able to jump it out and see if it lights
Oct 01, 2016 | Goodman Heating & Cooling
Goodman furnace furnace starts,flames start and shuts off after 10 sec. Replaced flame sensor still have same problem
if flame sensor is new, the board may not be properly recieving currrent from flame sensor to keep burners on
Feb 05, 2014 | Goodman Heating & Cooling
Top rollout switch triggers with blinking code *6*, Furnace only runs with cover off
restart unit as soon as your inducer fan came on pump the 2 wires to pressure switch and wait to see how long it stay also watch the flame at the burner
Jan 27, 2014 | Goodman GMS90703BXA Heater
I have a Goodman Manufacture furnace, model #GMPN120-5. The furnace keep clicking on /off while asking for heat. I even turned the fan to the on position (instead of auto) and the problem continues. ...
Can you tell me if the burners are lighting at all? I need a little more information about the cycle. If the burners are lighting and then going off immediately you need to clean the flame sensor. A small rod on the opposite end of the burners from the glow bar. Let me know if this is the situation, or describe the cycle completely and I will try to help.
Mar 19, 2011 | Goodman Heating & Cooling
I have a goodman GMPN1 gas furnace It goes through the cycle but doesnt fire. I replaced the ignighter it is working but still wont fire.
have you checked the pressure switch and also to assure that the flu is clear? can you light the burner with a match and when you do how long does it run for? have you checked the clearance to the burner have you also assured that where the ignitor is pluged into is cleaned ive also noticed on another site there is a board issue with this model have you checked the board ? also have a look at this site as well its where I usually talk with other techs about issues they have with the goodman as well as other units http://www.contractortalk.com/f6/goodman-80-furnace-brand-new-wont-start-7006/ please message me back with the answers to the questions that I have asked and I await your reply Thanks again Rick
Jan 31, 2011 | Goodman Heating & Cooling
Goodman furnuce cycling on lights, burner runs 6-12 sec, kicks out exuast fan runs, cycles through and does the same thing after 2-3 minutes, could this be the thermelacouple?
If your furnace has an ehxaust fan, your furnace does not have a thermocouple, it has a flame sensor. The flame sensor is a small metal rod that is in the burner area. It has one wire leading to it. Your problem seems to be flame sensor. If unit does not sense flame, it will kick off the gas valve.
Turn power off, take sensor out, (should be on 1/4" hex screw).. Probably some white film on sensor. Clean with steel wool, or dollar bill if don't have steel wool. Replace sensor.
Jan 24, 2011 | Heating & Cooling
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
Goodman GS9 propane furnace inducer motor runs continuously
it sounds like the low temp limit switch, the one that cools the furnace down with the burner off and the thermostat open, when it cools to a point the fan stops, the other switch in burner area turns burner off/on, hope this helps
Jan 31, 2010 | Goodman GMS90703BXA Heater
All burners will not light on Goodman furnace
I have had problems like this before. Most of the time it is the connection between the burners. There are small slots that the gas runs thru to lite. Clean those with a brush and then try it. Rus
Oct 04, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman GMS90703BXA Heater Logo
334 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
