Question about Sony Ericsson K850i Mobile Phone
Button came off n also phone is getting stuck
The delete and call disconnect button on my phone came off.... so can i just use some glue to stick it back or should i take it to the service centre???
also my phone gets stuck once in a while n wont respond forcing me to take out the battery.... so do i just need to do a master reset or should i go for software update???
    Guru:
  • 458 Answers
About the damaged keypad, i would sugest that you buy a new keypad, it does not cost much. Using glue will end up damaging your phone.
About the phone freezing, you might consider uninstalling some applications to free up space in your phone, or perform a factory reset to correct all the errors in the phone.
If that does not solve the problem, you might have to take it to a service center for a firmware update.
Thank you for using Fixya,
Kenneth
Posted on May 14, 2010
My iphone is stick in conncecting to itunes
try disconnecting the phone from the computer. then do a "hard reset" by pressing the slim button on top (the sleep/wake button) and the round button on the front bottom (home button) until the apple logo appears and then the phone turns off. Turn it on again by pressing the sleep/wake button. Try connecting to itunes again, if it doesn't work check for itunes updates or delete then reinstall itunes (your library will remain intact).
Nov 13, 2011 | Apple iPhone Smartphone
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
I have a glue gun (brand = POWER CRAFT a german product stated) I forced the glue stick into the gun to use up what was left of it and now I cant get it out. Its completly stuck inside the gun. Is the...
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Dec 07, 2010 | Crafts & Hobbies
Glue stick is stuck in glue gun and can't be removed.
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Sep 29, 2009 | 3M Crafts & Hobbies
All phone state that they are in use. I have
make sure the phones do not have intercom and is stuck on intercom.....buttons will stick on the keypads on these phones and it's possible that you might have sticking buttons....try each button and make sure they are not sticking down.....also, the key pads develop short circuits because of water vapour in the air or other things like pop spilled on them and so on....even if the buttons themselves are not sticking, they might still be shorting out because of a contaminated key pad.....in that case..you'll need to have it opened and cleaned with acetone or PCB board cleaner.....even alchohol will work but not as good as actual cleaners for boards...good luck
silvio
Jul 08, 2009 | Uniden Cordless Phone
Trash button stuck, how can I delete pics from camara & memory stick from computer
Go into your camera like you would your hard drive. Go to my computer then, look for your camera listed. Then there is usually a folder listed DCIM. Just look throught those folders. You will find the pictures. Then select them all by clicking and holding shift and delete.
May 09, 2009 | Cameras
P990i: touchscreen stick borken into two pieces and stucked in the hole accidentely
If you still have the other half of the stylus, put a tiny spot of super glue on the end of it and push it in the slot. Wait 10 minutes and gently try to pull the complete stylus out. Failing that use a tooth pick, flatten one end and do the same as described above.
Go easy on the glue it's much stronger than it appears, you don't want to glue the whole stick in the hole.
Feb 03, 2008 | Sony Ericsson P990i Cellular Phone
Sony Ericsson K850i  Mobile Phone Logo
74 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
