Question about RCA P61310 TV
My TV screen looks very green and not real clear? Not sure if the bulbs need to be replaced or settings need to be changed. I have changed some settings and it is a little better but still nothing like it was.
I have a philips magnavox 64" rptv, "99", model 9p644c. The picture is real dim. a friend gave it to me, but don't want to spend a ton of $ if I can buy one cheaper. Doe's it just need a bu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 21, 2013 | Philips 9P6444C 64" Rear Projection...
I have a philps 51pw9303 digital HDTV monitor. The picture has gotten very dull and dark. The colors are very dim and dull. Is this a bulb problem?
Check the convergence settings if necessary, try to check the bulb cause sometimes is getting weak. If you want to replace the bulb don't forget to reset the lamp hour meter. Let me know your feedback. Good day and God bless. Hope it helps.
Sep 02, 2011 | Philips 51PW9303 51" Rear Projection...
My colors are off on the tv seems to be really green. The red seems to flicker a little and the the looks like there is dirt all over the inside of bulb. Do I need to replace bulbs or try something else
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 21, 2011 | Philips 6P5430W 54" Rear Projection...
Picture very dark. I think I need to replace bulb. Can I do it myself. Where can I get bulb.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
Green tint on the screen
OPTICAL BLOCK IS GONE, 1000.00 TO FIX IT. SORRY, YOU MISSED THE RECALL DATE...JUNE 2009
Mar 02, 2010 | Sony KDS-R50XBR1 50" HDTV
I have the same problem(redish screen with no green at all)
Does Tube Light up? with TV on Look down into Tubes and see if picture is clear or you can bearly see picture or not at all Your Projection fliuld may need changing Ive seen where tubes are still lighting but No picture showing inside tube---- Bad Coolant Fuild Call Mats for fuild and for Tube if thats what it is Call Encompass 1-800-638-3328
Oct 05, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
I need a red green blue light bulbs for my pioneer
I suspect you're asking about the projection tubes. They don't all go out at the same time, there is some other problem. Also consider, you can almost buy a new TV for the cost of the tubes. I really expect you'll find the right answer in your owners manual. Look into the advanced settings.
May 18, 2009 | Pioneer Televison & Video
Bulb Replacement
It might be the the socket board on this model not the crt tube. Closely look at each tube these tubes end up contaminated. They start looking like lemonade inside. Usually the blue and green, with the tv off see if the green and blue are as clear as the red with a flashlight. You might want to call a service center. Cheaper in the long run over the cost of a tube.
Apr 17, 2009 | Philips 60PP9753 60" Rear Projection...
5yr old philips rear projecter tv color bad 50inch
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 01, 2008 | Philips 9P5034C 50" Rear Projection...
RCA P61310 TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
