I loaded two DVD in and they will not play Then I could not open the changer then flashed on screen not connected USB
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, postback with the brand and model number.
Have you tried unplugging for an extended period of time before trying again?
Good luck and thank you for asking FixYa.
Posted on May 14, 2010
Forgot password
  1. Download a software called Active Password changer.
  2. Install it in another system and insert a CD/DVD or a USB Pendrive to the system.
  3. Open Readme File in the Installation directory of the software and follow the instructions to load the inserted CD/DVD or USB with the software..
  4. Boot your system with the removable device (CD/DVD or USB) and start the password removal process.
  5. The rest of the steps will be explained in detail by the software readme file.
  6. your password will be removed
May 20, 2012 | Computers & Internet
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
I have model PD-F407-- It will not play past disc 5. I can not get it to manually play any disc past 5 and it won't roll over from disc 5 to 6. If I punch in to play disc 9 it flashes disc 5 on the...
Check that no CD's have dropped behind the load tray. The same issues happened to me and I found 3 discs that had fallen out and were blocking the mechanism from going past disc 5
Dec 24, 2010 | Pioneer PD-F407 25-Disc CD Changer
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
Rosen Dva3210 10-disc cd/dvd
You need to tune to the same FM frequency selected on the RFmodulator box e.g 87.5 MHz to listen to whatever is playing. Good luck. Do you know a website to down load the mannual?
May 16, 2008 | Rosen DVA3210 10-Disc CD/DVD Changer
How to play music cd's
Stop video playback first, then press CD MODE then press PLAY.
Dec 16, 2007 | Pioneer DV-C36 DVD Player
Clarion VCZ625 6-Disc CD/Video CD/DVD Changer
I would say to take it back regardless of what the problem is. I would say the unit is bad. Does the remote work the other functions? if it does not then the remote could be bad, if the remote does work the other functions, I would think the unit is bad.
Jun 23, 2007 | Clarion VCZ625 6-Disc CD/Video CD/DVD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
