Question about GE Nautilus 24" Built-in Dishwasher
I have a GE GSD4800G00WW Dishwasher problem. It
I have a GE GSD4800G00WW Dishwasher problem. It is discharging all of the water through the overflow. I have removed the screens and cleaned them both. Found a piece of glass and thought that was the problem. It was not. It is still discharging the water through the overflow. Any suggestions>
    Sergeant:
    Champion:
  • 232 Answers
If its over 5 or 5 you got your moneys worth get a new one.
Posted on May 15, 2010
CAUSE WATER LEAK
drain hose leaking from water pump discharge line
Jul 29, 2014 | GE Nautilus 24" Built-in Dishwasher
When my dish washer discharge water instead of the water going out the drain it come out the overflow valve.
The dishwasher usually drains into disposal, or directly into tailpiece, and water drains down to the p-trap.
Trap may be clogged or stopped up.
Clean out drain line, tighten connection where dishwasher attaches.
Clean out bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Kohler K-692-7 Clairette Kitchen Sink...
Dishwasher has no water
Find out where your water supply is turned on to your dishwasher. Usually it is under the sink and make sure the valve is turned counter clockwise to supply water to the dishwasher. If this is on, on some models there is a float switch that will sometimes get stuck in the overflow position. Look in the bottom of the dishwasher tub and you will see a round float. Usually it is in the front left of the dishwasher. Move the float up and down and you should hear a clicking noise. Make sure float stays in the lowered position, closest to the dishwasher floor. Check those two and let me know what you find. And we can go from there.
Apr 01, 2012 | GE Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
My GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try appliancepartspros.com for part # AP2617344.
Nov 30, 2009 | GE Dishwashers
Water shoots out of the water diverter or overflow on the sink but its not cloged
Yoou must be talking about the air gap for dishwasher discharge hose. This will show water if the inlet to the disposal is clogged and the water has a hard time getting through the inlet (it is a common problem). The problem is not with the dishwasher, Disconnect the rubber hose end to this outlet and check the inlet piece and check the hose that you just removed; you should see something clogged. Goodluck ,Macgivor.
Nov 20, 2009 | Whirlpool Dishwashers
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher conitues to fill even if unplugged
If the dishwasher is filling with out the power on, you have a defective inlet water valve. If it's new, have them repair it under your warranty. If not the part number is wd15x10003. Easy fix, on the left side behind the toe panel...Catriver...post back.
Aug 14, 2006 | GE 24 in. GSD4000J Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
319 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
