Question about Kenmore Kitchen Ranges
Oven problem we have a C970657092 kenmore smooth top stove, we turned on the oven and we heard a large pop noise, we reset the main breaker the first time it happened and it worked fine for a week. The next time the breaker did not fix it. we have a pf code on the panel and the clock flashes two numbers, there is no response when you try the oven. yes we changed the fuses, do we need to change the erc panel ?????
  • Jah Mike Oct 18, 2008
    I have the very same problem, where the clock is flashing and the pf light is on
    Problem Solver:
  • 6 Answers
You have to disassemble the control board (behind the touch pad). If you are the lucky one you might have to resolder the joint on one of the six relay (the largest one). If you are not i.e the spark damaged the micro processor.....you need a new board (318193201)
Posted on Oct 01, 2009
SOURCE:
Where are fuses in Kenmore stove C970
Stoves generally do not have internal fuses they rely on the house circuit breaker to protect the circuit. Some stoves have what is called a thermal fuse. These can trip when the oven or broiler has overheated. Some are located on the back panel and some are located on the top panel under the top of the stove. Since this is a smooth top model there may be one on the back panel. More than likely there is a problem with the oven control circuit possibly in the electronic control. The relays can go bad on the control and the oven will not work.
Oct 11, 2014 | Kenmore Electric Smooth Top Stove
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kitchen Ranges Logo
452 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
