Question about Whirlpool GEQ9858J Dryer
Gas Dryer no longer putting out heat.
My Whirlpool gas dryer (Model # is LGC664AQ1) is no longer providing heat It is almost 15 years old. What could be causing the lack of heat and how can I fix it?
  • Whirlpool Master
  • 43,501 Answers
Hi, If you have a gas dryerGas Dryer no longer putting out heat. - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif iGas Dryer no longer putting out heat. - 2_bing.gif"http://www.fixya.com/support/t4734648-dlg5932w_not_drying_completely_hear_gas#">electric2_bing.gif..
There could be a number of different problGas Dryer no longer putting out heat. - 2_bing.gif/>Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 14, 2010
Testimonial: "Thank you so much for that information! I will have my neighbor take a look at it today and let you know if it was indeed the ignitor. So helpful!"
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
6 year old dryer will not heat. Gas line & supply
Use this video to replace your gas ignitor.
http://www.youtube.com/user/RepairClinic#p/search/10/NVvI2kbOA-g
Aug 19, 2011 | Whirlpool WGD5320SQ Gas Dryer
We have a 10 year old Whirlpool Dryer Model #LGB6200KQ0 drum is turning but no heat. Could you please advise?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 02, 2011 | Whirlpool LGV4634JQ Gas Dryer
No heat. Elec. power OK. 12 years old
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
My whirlpool dryer, model LGC6646AWO will not heat. It doesn't sound like the electonic ignition lights up. what part most likely needs to be replaced? this dryer is 16 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Whirlpool Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer runs but don' heat up. It's about 15
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
heatman101
Mar 29, 2010 | Whirlpool Dryers
I have a whirlpool gas dryer, 4 years old. i
It sounds like the heating filament below the drum has either fried one of the fuses down there, or has some lint or something fallen on to it.
Did you notice if the drum still heated up? If it did, then its a bit trickier to completely ID what went wrong. If it no longer heats up now, then the thermal cut-off fuse has been blown and will need to be replaced (most common problem with a dryer)
Typically, once it is unplugged, you can open up the panel below the door (there are normally a couple of latches along the top gap that you need to push in with a couple of screwdrivers to open). Once open, you should see a heating coil that provides the hot air to the drum, look to see if there is anything in contact with the coil. If there is something there, remove it. If not, then continue below.
Now, if your dryer has stopped heating up, you need to pull the coil and replace the thermal cut-off fuse (or get someone in to do it for you). If it was still heating up, you can start the dryer with the panel open (make sure everyone and everything is well clear of the opening) and see where it is smoking from.
Nov 01, 2009 | Whirlpool GGW9868K Gas Dryer
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
Whirlpool Combo Washer Dryer LTG6234AW2 - Dryer wont heat
Go to: RepairClinic.com
There you can troubleshoot
you appliance.
You'll need make & model #.
Jul 19, 2008 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
253 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
