My acer dvd-rw is not working. it worked fine for a couple of months. i have an error msg Windows successfully loaded the device driver for this hardware (Acer esw860) but cannot find the hardware device (code 41). i have a power light, i can eject and insert a dvd or cd, but the Aspire One D150-1322 is not recognizing the dvd drive at all.
  • linda535 May 14, 2010
    my acer dvd-rw is not working. it worked fine for a couple of months. i have an error msg Windows successfully loaded the device driver for this hardware (Acer esw860) but cannot find the hardware device (code 41). i have a power light, i can eject and insert a dvd or cd, but the Aspire One Moremy acer dvd-rw is not working. it worked fine for a couple of months. i have an error msg Windows successfully loaded the device driver for this hardware (Acer esw860) but cannot find the hardware device (code 41). i have a power light, i can eject and insert a dvd or cd, but the Aspire One D150-1322 is not recognizing the dvd drive at all.
    See less
    Please accept or reject most recent solution
    Solution #1 posted on May 14, 2010
    NinaE
    Rank: Guru Expert
    Rating: 85.36% , 500 votes
    Hello, Linda.
    Your drive is faulty and needs to be replaced.
    If your Acer is under warranty, contact them for a replacement drive.
    If not under warranty, replace the drive yourself. It's fairly easy to replace: usually just remove the battery, loosen or remove a few screws and the drive is removed.
    Hope this helps.
    May 14, 2010 - Do you mean the DVD-RW drive or the Aspire hard drive?May 14, 2010 - The Acer DVD-RW is a separate DVD drive, attached and run by a USB with pigtails for power and connectivity.
    I'm not sure if it was the MANY Windows updates that finally got my dvd-rw working again, but after a last restart, the silly thing is fine now. Thanks for your help.
  • 4,281 Answers
First make sure usb cable connected to dvd-rw is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 14, 2010
    President:
  • 3,278 Answers
Hello, Linda.
Hope this helps.
  • 1 more comment
  • NinaE May 14, 2010
    Glad it's working. I suspect that there could be a problem in the near future. Thanks for using FixYa.
Sir, Am having acer aspire 5810T with windows xp OS. suddenly am not seeing the DVD drive in the my computer and the drive does not work. IN the device manager MATSHITA dvd RAM UJ862AS is...
Code 41 means the driver is either not loaded or corrupt.
Download a fresh driver from Acer and update the BIOS at the same time as that can give errors similar to this.
Dec 28, 2010 | Acer Aspire TimelineX 5820T-5951 Notebook
DVD-ROM and DVD+RW
Did you do a system "Restart" after the driver install? Sometimes that is all that is required to enable the device to work.
Sep 11, 2009 | Intel DG31PR Motherboard
Gateway M-6848 arrived with vista home. used
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 14, 2009 | Philips (JR4DVDRWK/00) DVD+RW Burner
Dvd-rw gwa-4082n wont work
tampered connection cable with DVD rom is the problem get it repaired it will take not more than 5minutes to repair.
pls rate my solution
thankyou
Feb 11, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
I have a 5 month old acer laptop that came with a dvd rw doudle layer disc burner.... this is what it says when i find discription in the computer.... 6.0.6000.16386 version driver# signed by micro...
You have to manually download the latest drivers from the Manufacturer and then point Vista where it is when the New Hardware wizard tries to install it.
Or your best bet is to go to Acer's support site and download the Driver for your DVD drive.
http://global.acer.com/support/download.htm
good luck,
djEnigma
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
