Question about Fantom Drives GForce GreenDrive 1 TB USB 20 Hard Drive
Which is better for my external hard drive?
Which is better for my external hard drive...leave it on all the time and let it go to sleep by itself, or should I turn it off whenever I'm done using it? Thanks in advance!
  • 32 Answers
Click on safely remove hardware icon and stop the device when your done using it
Posted on May 14, 2010
Spinning wheel death
a new computer? how old is the computer your using and how old is the external hard drive? chances are either the computers pulling every gram of memory out in an attempt to search the hard drive for what you want leaving nothing for you to do other work with. might be upgrade time if its getting on in age.
if the hard drives ageing your going to be better off turning your external drive back into an internal one if you have a tower. you should have room to mount at least 2 drives into the tower. just buy a new hard drive connector and plug it up. the older USB drives work a good bit faster directly connected to the system.
Feb 14, 2014 | LaCie Computers & Internet
It decides for itself when to work or not. Plug in, no power. When it works it can function for a while but just suddenly shut down and doesn't go on again like I want it too.
A lot of external drives have a "sleep" mode that triggers after a few minutes of idle time, which can appear to be "off". If you are not seeing power (is there an indicator light?) then check the cables connecting the AC power adapter. Maybe the connectors are dirty and not making a clean electric connection.
Jan 10, 2014 | Western Digital 3TB My Book Essential USB...
My WD mt passport 2TB keeps ejecting itself all the time. The problem is that I have my entire iTunes library (1tb) there. I wont to copy the library to another disk but the drive ejects itself all the...
You can disable the sleep timer in the settings menu. Details can be found on page 34 of the product manual:
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705020.pdf
Passport drives are generally used for backups so they like to turn themselves off to extend their life cycle. If you want to use an external drive for frequent media use, I recommend WD Elements.
Sep 26, 2013 | Western Digital WD My Passport 2TB USB 3.0...
Seagate freeagent keeps dropping disconnecting
Seagate manufactures both internal and external hard drives, and their sleep modes can be managed in different ways. The hard drive is one of the top energy consumers among computer-hardware components, and Windows operating systems support options to reduce power consumption. Internal hard drives are typically turned off and stop spinning ("sleep" mode) after a certain period of system inactivity. However, the system usually takes longer to come back when the hard drive's sleep mode is activated. Furthermore, turning off hard drives may result in failure of some constantly running applications.
Windows includes options to turn off sleep modes for internal hard drives, and external hard drives can be managed using a utility program.
Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and then "Systems and Maintenance." b> Click on "Power Options." Open "Change plan settings" under your current power plan. Note "Radio button" is selected for the current plan. Click "Change advanced power settings." Expand the entry "hard drive" by clicking on the "+" sign. Click on "+" to expand the entry "Turn off hard disk after." Select "Never" for this option and click "OK." b> In Windows XP Log in to an administrator account and click the "Start" button in the lower left corner of the screen. Click "Control Panel" and switch to the "Category" view on the left panel. Then click on "Performance and Maintenance." Click on "Performance and Maintenance" and open "Power Options." The select the tab "Power Schemes." Using drop-down list, set the option "Never" for "Turn off hard drives." Click "OK." b> Using "NoSleepHD" for External Hard Drives b> Click on the "NoSleepHD program" link in Resources. Click "I Agree" and save the program (as a zip file) on your computer. Open a folder where you have saved the file using Windows Explorer. Right-click on the zip file and select "Extract All." Then click "Extract" to get the program file "NoSleepHD v1.0.exe." Double-click on the program (.exe) file to execute NoSleepHD. Click "Select External Hard Drive" in the Program menu and choose your Seagate external hard drive. Choose "10 minutes" under the option "Write File every" and click "Start NoSleep Mode." The program will write an empty string every 10 minutes to the Seagate hard drive and prevent it from going into sleep mode. Hope this helps.
b>
Dec 29, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I am trying to back up my MacBook pro via the wd software and my external harddrive keeps on shutting down by itself. By that I mean the light on the harddrive goes out. I the try the same thing on the...
There is a WD utility that controls the drive setup. One thing it controls is the sleep time. This sounds like what you are seeing. I know the default sleep or hibernate time is annoyingly short. All you need to do is run the utility look for the sleep time and change it to a much longer period. I don't think it can actually be disabled but you can set it to an hour or so.
Sep 21, 2011 | Western Digital 1TB My Passport Essential...
I have a Seagate expansion external hard drive, i can connect it, but how do i use it-keep it simple
Put all your documents in my documents folder of your hard disk
or install the software come along with him CEEDO in the hard disk itself.
Always connect both the USP prot of the cale to the PC for better efficiency
Jan 15, 2011 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Disconnecting unexpectedly!
Hello! My recommendation would be to check if the Drive is over heating. Excessive heat could cause the disconnection either for drive protection or because solder points lose strenght. Turn it on, use it a while, right when it disconnects check if its hot. Or try to dissipate better the heat and see if it lasts longer
Mar 22, 2017 | Buffalo Technology DriveStation Combo 4 1...
Can I leave my Seagate expansion external hard plugged in
Hello
Yes, you can leave the device plugged in, you do not need to unplug it if you turn off the computer, do remember to safely remove when you plug it out though.
Kind regards
Andrea
Dec 26, 2009 | Computers & Internet
Failure pridicted on hard disk 2
Immediately back up your drive contents to an external USB hard drive or other device. Buy a new hard drive, install it according to the instructions. Many drive manufacturers include software and directions to copy the complete contents of the old drive to the new drive. Hopefully, you'll be able to get this accomplished before it all comes tumbling down. The fewer times you shut it down and restart it, the better. If the information on the drive is critical, get something like Acronis drive imaging software to "snap" an image of the drive and put it on an external drive. If you haven't burned the restore disks, follow the manufacturer's directions so that, at worst case, you can get it back to factory new condition, which will leave you without your files.
Aug 04, 2009 | Gateway 40G / 40GB for laptops /...
Sud I turn off my p/c every night or just let it go to sleep
There is a lot of controversy over this issue, and it depends on how you use your PC. I use my PC for business, from 8-16 hrs a day. The best time to scan for viruses and perform other maintenance tasks is when I'm not using it, which happens to be while I'm sleeping. I set my PC go into hibernation, so it will 'wake up' at 3 a.m. and perform the full virus scan. There can also be problems with 'cold starts' on your hard drive if you turn it off every night. My recommendation is to leave it on, but make sure you have proper energy savers for the screen and hard disks on so it doesn't waste power.
May 30, 2009 | HP S7620N Pavilion Slimline Desktop PC -...
Fantom Drives GForce GreenDrive 1 TB USB 20 Hard Drive Logo
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
