Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink never dries
No matter what paper used (photo, bond, etc) ink will smear if touched, even days later. Ink never dries.
  • 518 Answers
That is an unusual problem. Are you using Original HP cartridges? Some of the refills can do weird things.
Hope that helps...
Posted on Mar 30, 2008
Most likely the media (paper) is touching the print heads. This can occur because 1) the media holding mechanism is not holding the media correctly, and the media buckles, or 2) the carriage to media distance is too small. (Check the adjustment in chapter 5 of the manual).
I found a copy of the procesure online:
HP DesignJet 430 Service Manual Adjusting The Carriage To Media Distance
Dec 21, 2017 | HP DesignJet 450c InkJet Printer
Printing 8 x 10 photos
When it's humid out it takes longer for the ink to dry. Especially for larger photos where a lot of ink is used. Also, lesser quality ink takes longer to dry. I would recommend using a dehumidifier in the room where you are printing the photos to dry out the air a bit and allow your ink to dry quicker.
Jul 28, 2012 | Epson Easy Photo Print
HP inkjet printer. any drop, splash or bit of water causes a smear on the paper. Is it the printer or the ink??
It is the ink and paper, it is ink water will make it smear, There are some special inks and paper but cost more.
Sep 02, 2010 | Office Equipment & Supplies
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
How do I clean the printer nozzles as it leaves streekes on printed pictures?
If the ink is smearing, it probably is not getting enough drying time. The ink drying time is a period of time inserted between pages to reduce the chance that a page will smear the one below it in the output tray. This time is factored into the time between when the first page finishes and when the next page finishes. Printing will pause temporarily if more time is needed. The time it takes for ink to dry varies greatly depending on paper type, printer driver settings, humidity, and temperature. In addition, the paper and print settings may affect the speed at which the ink can dry:
  • Transparencies require much longer drying times than other paper types.
  • Some store-branded photo papers do not allow ink to dry correctly because of the coatings used in their manufacture.
  • Printing in Best mode can increase the dry time.
Resolving the problem If the ink smears, increase the drying time. To increase the drying time in Windows, follow the steps below:
  1. When ready to print, click File , click Print .
  2. Depending on your driver version, click Properties , Settings , or Preferences and follow the steps below depending on the option.
    • For Properties or Settings , follow the steps below:
      1. Click the Advanced tab.
      2. In the Extra Dry Time section, move the slider toward More .
    • For Preferences , follow the steps below:
      1. Click the Basics tab.
      2. From the Basics tab, click Advanced Features .
      3. In the Extra Dry Time section, move the slider toward More .
  3. Try a sample print and see if the drying time needs to be increased more.
To increase the drying time for a Macintosh computer, follow the steps below:
  1. From the File/Print Menu , select Ink under the General tab.
  2. In the Dry Time section, move the slider toward More .
Other steps that will reduce ink smearing If the ink still smears when printing, try some of the following suggestions:
  • Decrease the amount of time it takes for the ink to dry by decreasing the print quality to Normal or Fast mode.
  • Try printing on a different type of paper or on paper from another manufacturer. Paper formulas are different between manufacturers and may have a coating that causes the ink to be absorbed at different rates.
  • When printing large graphics or photos on plain paper in Best or Normal modes, improve the results by using heavier paper. Paper that is rated at 90 g/m2 (24 lb.) or higher will not curl or smear as easily as paper of a lighter weight.
Mar 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Printing photos on hp psc 1215
Are u using the original HP ink ? The HP ink is formalated to dry fast. You might try using a different ink cartridges, but try a couple sheets of HP photo paper to see what happens.
Apr 21, 2008 | HP PSC 1215 All-In-One InkJet Printer
Black ink smears on photo as it prints
Some of Epson's ink have inconsistent quality. Some batches have runny ink. Nozzle cleaning and print head alignments don't help at all, if they didn't make it worse in the first place. I've experienced problems like yours several times as well. Here's what I did that worked for my Epson 960. Move the printer to a really dry place. Take out all the ink and let the printer sit and dry for a few days and then change all ink cartridges. Make sure you buy newly created ink. All Epson ink come with born-on dating so find the ones with the most recent dates and make sure the whole batch is produced at around the same time to ensure color consistency. Plug them in and try it out. If the problem remains, you may need to bring the printer in for repairs.
Jan 06, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Ink won't dry
Unless the problem coincides with a change in ink cartridge, my guess is an incompatibility between the ink and the paper. Could you have changed the paper you're printing on. If so, is the new paper of a different quality? If you're using coated (eg photo) paper, are you printing on the right side? Check the "paper quality" setting on the printer (or the software you're using to drive it) - it needs to match the specification of the stuff you're printing onto. Photo quality papers are capable of absorbing much more ink than plain paper (which is how you get the colour intensity). If the printer thinks it's using photo paper, it will throw out enough ink to get that colour build - leaving a sticky mess if what is really loaded is just plain paper. A.
Apr 28, 2007 | Canon i860 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
94 people viewed this question
Ben Johnson
