Question about Hunter (25417) Ceiling Fan
Remote control won't work any more
How can i diagnose why the remote won't work for the fan?
  • celgel May 14, 2010
    I can pull the pull chain to turn light on and off, but nothing happens when I pull the chain for the fan?
  • celgel May 15, 2010
    Is there a way to tell if the capacitor fan speed control and light dimmer is bad?
  • 11,896 Answers
Have you tried to replace the batteries in the remote? Have you tried to clean the IR sensors with rubbing alcohol and a cottons swab or windex?
Posted on May 14, 2010
  • Nate Stansfield
    Nate Stansfield May 14, 2010
    Sounds like it isn't the remote but possibly a bad fan motor or a broken wire to the fan motor itself.
  • Nate Stansfield
    Nate Stansfield May 16, 2010
    Best test would be to use a voltmeter. Find where the power is going and not going.
    You can test parts of the fan such as capacitors and such and switches with an ohmmeter in the ohm setting. The reading should be infinity.
Can a the transmitter and receiver be replaced by wall control for a Hunter fan model 28425?
The part # you need is 85662-01-000. Maybe you can find it somewhere in cyberspace.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan. Remote control. Lights work, fan won't. Batteries in remote new.
If the fan came with a remote you probably need a new receiver. You can order at 1-888-830-1326. Need model #
Jul 07, 2013 | Dryers
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
The light works but the fan won't work
Was it an add-on light? If so, pull the light switch once and try the remote again. If not, you probably need a new receiver.
Mar 24, 2013 | Hunter 52" Ceiling Fan With Light And...
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
Hunter ceiling fan model 23285-420 w/remote control...worked fine for about a year then lights would start flashing when turned on. Changed remote control and receiver with no change. Eliminated the...
The problem is not your remote on the fan. It is the light kit. We have the same problem and our electrician diagnosed it as the light kit. This problem started just out of warranty, of course, and we are now purchasing a new light kit to fix the problem.
Jan 28, 2012 | Hunter Ceiling Fans Individual...
Emerson CF4800 with SW375 receiver that does not turn on fan!
Please excuse me if you already have the answer, but I went thru the same thing and found that the actual receiver was broken. The receiver that is found in the top part of the fan itself. I was able to diagnose the problem because I have two of the same fans in the house and when I switched the receiver units, the broken fan started to work. Hope that helps.
May 30, 2009 | Emerson Fans Emerson SW375 Receiver
Hunter (25417) Ceiling Fan Logo
280 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
