Question about Pentair Challenger High Head 1.5 Hp Pump Up Rated
I need an electric pump to pump water from the creek to my garden.
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Go to a local home center, hardware or pump store (landscape or pond supplies) and get a self-priming pump that is rated for the delivery you need and the system head that will be present in your installation. Add a semi-rigid flexible suction line with a foot valve and protective screen at the end and a manifold to the discharge that includes a spigot to hook a hose to and you're all set. It will probably run a few hundred dollars if electric driven. If you need a gas driven unit it will be a bit more.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 14, 2010
Can the pool overflow from rain?
A pool will over flow in the rain, the pool pump is only for circulating water not for draining overflow , you can go to a local pool supply and buy a pump to hook to a garden hose and drain it partially, be aware that the pump runs on electric power and you want to be careful not to drain the pool below the skimmer level or you will end up replacing the pool pump motor
Dec 11, 2014 | Jandy Pool & Spa
Why hot water heater on my cedar creek travel
You needed to post more info. does it have power to the heater. Is it electric or gas? if electric and it has power to the heater you need to check with an electrical tester if there is power across the element terminals, If not it needs to be replaced
Oct 12, 2014 | Water Heaters
Brand new Wel Bilt 1 HP shallow well pump, shuts off after running for 5 to 10 min !!! Help ! JGP12001CHT (Northern Industrial Shallow Well Pump. Installed to pump creek water for yard, runs at 30 PSI on...
It sounds to me like you have a defective thermal switch that is shutting power off as if motor is overheating.Unless you are exceding the head or flow ratings on the pump I would recommend you return it for replacement.Thank you.
Jul 13, 2011 | Plumbing
My pumps hose broke and the motor kept trying to pump water, but when the tank was empty the pump kept going. Now that the pump is full I have problems with the pump continually priming itself and not...
i need to know is your pump petrol or electric/ and did your suction or delivery hose brake/when you say the pump is full do u mean your tank is full of water /if your pump is house water 240volt with tyre type valve on top of pump u need to get pump[ pushbike type pump] and repressure the bladder in that pump , check pressure specs on your pump
Jan 18, 2011 | Garden
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
Milky oil leaking from left side caseing?
If water gets inside the gearbox, it will emulsify due to the "blending" caused by the gears and crankshaft. It turns the oil a milky color. The water can come from a bad oil seal on the water pump (if the bike is water cooled), or from condensation inside the gearbox. Sitting out in the rain, pressure washing or riding in creek beds can also be the water source. Find the water source and fix the seal or otherwise remedy the exposure. You will need to do an oil change. Please rate my answer. Thanks.
Sep 13, 2010 | Honda NSR 125 R Motorcycles
Hello, We have 144 HVAC units in hotel. We do not have drain to release condensation water, as a result water flows through walk way and makes it wet.
Common problem at hotels. Affordable Solution choices are to (1)catch in container (drain daily), (2)catch in channel or tube and direct along building to better drain site or into groove in cement (cut one if needed) leading to rain gutter. Finally there are higher cost solutions, which are (1) Pump style. Small plastic pump and water resivoir are set below and drainage goes into device using pvc (typically) clear vinyl or pvc is then directed from pump up hill or wall or anywhere you want it to go to find good drain site or garden patch. Pump is electric and will need to be plugged or wired in and will pump out water as it collects. (2) They make electric water evaporator units that catch the water and heat it up so that it evaporates faster than the container can fill up. this may be available through daewoo and could possibly be installed inside or just below the unit.
Jul 20, 2010 | Daewoo DWC063R Air Conditioner
My 1995 Toyota Tacoma 4 cylinder 2.7 liter automatic 4wd is missfireing on three of the four cylinders. The miss fire is very random happening more and more frequently. I have good compression and timing....
Pull codes from OBD computer go from there. Could be other problems, check fuel pressure, All electrical connectors- loose, water, dirty, ground connections, etc. Could be a failing sensor. How do you know its missfiring on 3-4? one or two cylinders would be a really bad shake. Creek is to deep stay out of creek. Good luck!
Mar 16, 2010 | 1995 Toyota Tacoma
Pentair Challenger High Head 1.5 Hp Pump Up Rated Logo
103 people viewed this question
Top Pentair Garden Experts
Dennis Key
Dennis Key
john h
Are you a Pentair Garden Expert? Answer questions, earn points and help others
