Question about Sony CDP-C910 10-Disc CD Changer
Sony 10 disk cd player CDP C910
Sony cdp c910 Cassett magazine will not lock in place
2 Suggested Answers
budgie140
  • 502 Answers
SOURCE: My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Posted on Jul 11, 2010
Testimonial: "Very kind to have answered so promptly and provide insight."
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
WILL THIS MODEL PLAY MOVIES
No it won't. It's just an audio CD player.
Jul 22, 2011 | Sony CDP-C910 10-Disc CD Changer
The sony model #CDP-c910 skips discs continually and does not stop to play a disc. Am interested in repairing this set or purchasing a new identical set if it is still available. The size is...
Try changing the (only) belt the player has with a brand new one. Go to www.partstore.com. I believe it costs more than $10. Clean the pulleys with isoprophyll alcohol using a cotton swab after removing the old belt.
After you remove the top cover, take a careful look how the belt is placed. Don't unscrew anything. The belt can be removed and replaced without removing any screw. A paper clip will help if you don't have the right belt removal & replacement tool. A commercial CD lens cleaner (I use Scotch brand) will greatly help. Just insert it in your magazine and run for a few seconds to a minute. This is not a sure fire solution but most of the problems in this model is attributed to an loose/overstretched old belt and a dirty laser lens. I hope this helps & good luck!
Jun 10, 2011 | Sony CDP-C910 10-Disc CD Changer
The cd player on my kenwood ud302 is jammed shut with cd's inside...how do I open it .....any ideas please?
Barbara,
All CD and DVD players have a small hole in the front of the tray. This is for situation like you are in. Insert a paper pin into it and press a little when you encounter resistance. The tray will unlock and open.
Jan 11, 2011 | Sony CDP-C910 10-Disc CD Changer
Jul 11, 2010 | Sony CDP-C910 10-Disc CD Changer
Motor runs continuously
hi there try to disconnect the power as it is doing this wait 10 seconds then hopefully the unit has reset itself as it might be a control board glitch. Have you recently installed in a new car if so check that you have the correct connection as if the pin outs are incorrect can also cause this problem.
Thanks J
Feb 16, 2008 | Sony CDP-C910 10-Disc CD Changer
Sony CDP-C910 10-Disc CD Changer Logo
273 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
