Question about GE A830 Digital Camera
Having trouble with lens error message - GE A830 Digital Camera
    Sergeant:
  • 420 Answers
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 11, 2010
I keep getting error 99 message
Error 99 is common error on Canon cameras. Make sure the battery is freshly charged. Take the battery out, the compact flash card out, and the attached lens off of the camera. Leave the camera set for a while for the capacitors to bleed off. Around a half hour would be good. Next re-insert the battery and push the shutter button as if you were taking a picture. If you get an Error 99 then, you can't fix the trouble and Canon will have to do it. If you do not get an error 99, power the camera off, insert the compact flash card, power the camera back on and press the shutter button again. If you get an Error 99, the trouble is in the compact flash card or its connector. Try a different card. If you do not get an Error 99, power the camera off, a lens on it, power the camera back up, then press the shutter button once again. If you do not see an Error 99, the problem is no longer in the camera. If you do see an Error 99, power the camera off and remove the lens. The problem is probably in the contacts on the camera or the lens. Clean the contacts by holding the camera carefully with the lens opening down so it will not allow dirt to get inside the camera. Take a cotton swab dipped in alcohol and clean the gold metal contacts well, Dry the contacts with a tissue. Next hold the lens with the contacts down and repeat the process on the contacts on the lens. Be very cautious not to allow lint, dust, or alcohol to get into the camera body or into the lens. Some people use a pencil eraser to clean the contacts but you have be very careful not to let particles enter the camera or lens. This should clear your trouble, if the camera passed the first step of troubleshooting.
Nov 02, 2013 | Canon EOS 40D Digital Camera
I have a Sigma DL Zoom 75-300 mm lens that I would like to use on my new Canon Rebel T3i SLR camera. Part of the time when I try to use it, an error message comes up saying, "The lens is having...
Simply clean your camera lens contacts
Here is a tutorial , how to clean your camera lens contacts
http://www.youtube.com/watch?v=wUt-K6w7lc0
Good luck and regards
Sep 29, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Nintendo wii message reads: error occured remove disc turn off console check operations manual for information! on 2 new games
Some older Wii units also have trouble with Dual Layer Discs, which pack more info onto a disk like Super Smash Bros. Brawl and Metroid Prime. If your Wii is having trouble reading a dual layer disc you can try Nintendo's Wii lens cleaning kit. the other resolution for this is to change the laser on the system but it will cost you for that. Try to clean the lens first it might read the new disk.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo Wii Console
Why during the update for my system does it get 67% of the way through the update, then stop, and bring up a trouble code 80010006, and how do I fix it? PLEASE HELP!!! forever gratefull wes
Hi. The lens og the console stopped working for some reason that is why you are getting this error message. Try cleaning the lens by using a qtip and alcohol. If same issue happened after cleaning the lens. This could be a lens problem.
Sep 06, 2010 | Sony Playstation 3 (PS3) Console
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
GETTING A ERROR L
L1 = Mirror feed trouble,check the mirror motor.
L2 = Mirror motor lock
L3 = Mirror returntrouble
L5 = Lens trouble,check the lens motor,sensor and driver board.
L6 = Rotary casette trouble
L8 = Full wave signal error
L9 = Sorter trouble.
Nov 24, 2009 | Sharp AL-1642CS Copier
Lens error message(nikon l16)
I was having a "Lens Error" with my Nikon Coolpix S10 camera and this websites' tips fixed my camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good Luck!
Sep 27, 2009 | Cameras
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
Inserted disc reading "No Disc"
Hello Brian,
It looks like you have a bad lens assembly. That explains the "No Disc" error. Just get the lens assembly replaced and it will be back to normal.
Jan 31, 2009 | JVC DR-MV1S DVD Recorder/VCR
GE A830 Digital Camera Logo
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
