Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Video Label The video label that appears when you change inputs and normally then disappears, no stays on. Even when I change from input to input, the label does not fade. Any thoughts?
There's a "Display" button on your remote.  Push it.
Posted on Mar 31, 2008
6ya staff
SOURCE:
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
Blue screen that says RGB on my vizio
I'm sorry for the difficulties you're experiencing in watching programs on the TV. Since the screen says RGB, it appears that you've selected input as RGB(VGA, also known as PC input). If you have nothing connected to PC input (RGB), please change the input to HDMI or component or what ever it is by using the input button on the Remote of the TV.
In some TVs INPUT Button is labeled as TV/Video. Press it repeatedly to change the input from one to next.
Thanks for understanding. Please let me know if you require any clarifications.
Jul 05, 2011 | Vizio L32 32 in. LCD HDTV
I am hearing a ticking sound coming from all speakers. The volume does not adjust the intensity of the ticking. Is there something wrong with the reciever or could there be a problem with the wiring?
Disconnect all signal input cables and see if the ticking persists when the system is switched on. If it does not disappear you have a problem that needs a Technician to check out. If it does disappear, you can try putting in each input cable one by one and selecting it to see which input is causing the ticking sound to appear. Then further check the input source equipment.
Apr 21, 2011 | Denon AVR-2805 Receiver
I have an RCA television (Model #: F27443). I need to change the tv/video to video, but I don't have a remote. Also, there is no button for tv/video on the front panel for this particular model.
Hi - Push the leftmost button on the front panel, labelled Menu. Go to "list and labels." I'll bet that you will find that the inputs have been switched off. Switch them on and they will appear in your normal channel line-up.
Feb 26, 2011 | RCA F27443 27" TV
F27442 - How to display signal from front panel RCA video input
To display signal from that input you will need to change the input on the tv. This can be done either on the front of the tv, or by using your remote control. First power on and connect the desired source. Next on the tv or on your remote, press a button labeled either source or tv /video and scroll through by continuously pressing until you see the source you connected appear on the tv display.
Good Luck
Jan 07, 2011 | RCA F27442 27" TV
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Video Input Label Displayed Constantly
You need Sony TV remote and press Display button and screen display (green label) will disappear.
Regards,
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Video 7 remains on screen
if your on input "video 7" but there is no picture, this is normal. however if you have a picture and video 7 remains on the screen,then on the original remote there's a button labeled "display" press that. video 7 should disappear
Jun 01, 2008 | Sony KDSR50XBR1 50" Projection HDTV
Long time to power up video
My Sony KP-53XBR200 will not display any video (even from the tuner) except the internal display until it sees a video input on one of the video jacks on the back after a power hit.
I solved this by putting a video cable from Monitor out to Video 4 in (unused for other video). Voilla! Instant video on. This may not be your issue, but it fixed my set!
Oct 20, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
