Question about Innovage (1504368) AM/FM/Weather Radio
The recharable battery is no longer holding a charge, can I replace it?
  • 311 Answers
You can replace the battery but it requires opening it
finding the battery inside
finding the voltage and mA of the battery
and then looking for another battery with similar diamentions and values
if you have never done anything like this before i dont recomend it
but it couldnt be that hard, the hardest bit is finding another battery,
if you try and do it youself then i few tips on the battery
the voltage might or might not be written on the battery (hope it is) when you look for a battery the voltage has to very similar id give or take 0.2V each way
the mA of the battery can be anything when you buy a new one just make it bigger than the original (so you have more battery time)
Posted on May 14, 2010
G'day i have a 2007 npr 400 and recently it wont tip when i engage PTO can you tell why that may be?
MetroKane E RABBIT portable rechargeable battery wine bottle cork screw. I need a replacement battery. Present battery in it is recharable group of three batteries spot welded together with bridges recharged by a 8.5 volt charger. Each of the batteries are the size of a AA standard, with no raised end to designate polarity. Using my VTRr, with no load I get 8.5 volts. Each cell alone reads 3 volts.
The present batteries will no longer hold a charge strong enough to run the Cork screw.
Thanks for your assistance.
Mar 16, 2018 | Garden
Camera says battery empty
When you finished chargin the batteries, was it fully charged? Are you using the AC cable that was provided to you witht the device? if your camera showed that it was fully charge but discharge even though you dont use the camera,I would recommend you to replace the batteries on the device....
Jan 17, 2008 | Olympus FE-210 Digital Camera
Battery not recharing
You need a new battery or a new battery charger. If it shows that it is charging but does not charge the battery then it is the battery itself. If it does not show that it is charging then it is the charger.
Feb 06, 2016 | Computers & Internet
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Unit will not charge
THE UNITS RECHAREABLE BATTERYS HAVE SPENT OUT THERE LIFE CYCLE. YOU WILL HAVE TO REPLACE THEM WITH THE SAME SIZE RECHARABLES.
Feb 23, 2011 | Black & Decker 15.6 Volt DustBuster Vacuum
Battery only can use half day
If the recharable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Dec 22, 2009 | RIM BlackBerry Bold 9000 Smartphone
GPS WON'T FINISH LOADING
hold down reset button for 3 secs. then hold down power button while holding reset button until the boot menu comes on the reboot or pick update os. note: u must 1st use reset button to choose the options the the power button...
Jan 15, 2009 | Nextar X3-03 Car GPS Receiver
Battery won't hold a charge
Buying recharable batteries will not solve the problem of the battery draining quickly but will help save $ by not having to purchase so many disposable batteries. Check your user guide to see what kind of batteries your camera will accept. Lithium ion rechargeable is the best if compatible. Lithium ion disposible (CRV3) will last a long time as a secondary choice if compatible. Some cameras drain batteries more quickly than others. Just a tip to help reduce the drain: don't use your LCD screen when unnecessary (such as scrolling through several of your pics in-between snapping pics).
Nov 25, 2008 | Olympus FE-230 Digital Camera
Innovage (1504368) AM/FM/Weather Radio Logo
630 people viewed this question
Top Innovage Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Innovage Audio Player and Recorder Expert? Answer questions, earn points and help others
