Question about Dell Latitude D600 Notebook
My laptop won't take a charge, bought new adapter. No luck.
My Dell Laititude Laptop stopped taking a charge(the battery died, I hooked it up to the adapter..it wouldn't turn on or charge). I assumed it was the adapter, bought a new one, tried to charge it..no luck. Any thoughts on what else it could be?
  • today25er May 14, 2010
    When I tested my original Adapter the LED light turns green. When I plug it into the computer it the light does not turn on. I assume this means it's not charging the battery. I checked the battery for signs of damage and the connections as well. They look fine(and newish) to me. Is my battery toast?
  • Dell Master
  • 4,924 Answers
To see if it is something with the charging process..I ..if I was in your place get it to a store...where you bought the battery ..and ask for a charged battery and try it on ..if it do not power up..it means that it is something wrong with the power line of the mother board...or with the CPU ..or the mother board...Remember ..the first time you thought the battery is dead...you should have checked if it opens cause even with no battery at all they have to function when is plugged on the power adapter/charger..if it do not...and it work with a charged battery ..than the charger itself is to blame ...but if both charger and battery are ok ..than is the motherboard ...
When only the cpu is to blame ...the actual lights will light ..the power..(that indicates the curent into the main board) ...and when the battery is in and the charger plugged..the green light that shows the charging process had to be on also..
If no light is on ...you will have to see if a plug on the main board is not accidentally unplugged...or the mini board for the power button ...it may be also unplugged or damaged...(for this one only remove the snapped in cover of the hinges..and take a look on the ribbon that plugs on the main board)
if nothing at all is lighting on the it ...this is either a contact (if you are lucky ..and you can detect the break with a measurement tool for voltage ...just follow the power line in ...after you take it apart ) or is the motherboard itself...and you will have to change it all..cause they are pretty compact..and in this case either buy a new one ...or look for a second hand with the display broke ...or stripped ..and just take the board (this is the cheapest but risky way )..
Let me know what you have done ..and how it behaving ...but to tell you from the start ..if no power light is on...this is the board ..
Posted on May 14, 2010
  • Catalin Turcu
    Catalin Turcu May 14, 2010
    I sow your comment and Im sorry to disappoint you ...I suggested to try an already charged battery from a similar model in a shop...but ..if the laptop is not working with the plug of the adapter in ..it means that it has other issues than the battery cause in general it should work without battery inside just directly on the adapter This is what I already explained earlier..If the green is on .t means that they are both ok ..but if the power led is not, it means the mother board do not receive power..and this is the issue ..either is damaged..or its a short somewhere..or is the plug to blame...but the fact that it do not runs on battery it means the board its probably gone..
    Genius:
  • 1,354 Answers
  1. Check the Battery and Connections:
    1. Remove the battery from the system.
    2. Look at the connectors in the bay and on the battery for signs of physical damage.
    3. Check the battery charge by pressing the status button or image on the battery near the LED's.
Note:
The lights indicate the current amount of charge on the battery. If all the LED's come on when you press the button, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flash, or blink, there could be a problem with the battery.
D. Consult the Tell Me How guide for more information on battery LED's:
E. Where to find the Dell Tell Me How and User's Guides
    1. Reinsert the battery; push until it locks into place and the latch snaps back to the locked position.
  1. Swap Bays or Try A Second Computer:
    • Some systems can run with the battery in either bay. Try swapping bays if you have one of these systems.
    • If you have access to a second computer like your own, try to charge your battery in that system.
    When I pressed the button on the battery no lights lit up...thoughts?
  • if you have done all above instrctions it mean bettry is gone your have to replce that
    if your laptop is less then one year then takit to the dell service center
    contect me if any further require any halp
My Dell Inspiron 3520 laptop is not charging, the charger/adapter is not working. I cannot fix it, bought new battery and adapter and they do not charge. What do I do?
Is the plug that you connect the adapter to still properly connected to the mo bo? If not, the adapter will not work nor will it properly charge the battery. Bet that if you charge that battery to another working laptop your new battery will take a charge.
Sep 04, 2017 | Dell Computers & Internet
Tip
How to Test Your Laptop Battery?
How to check charge times for laptop battery?
install all drivers and laptop batteryMaximiser ThinkPad configuration software, then open the “ControlPanel” ——”Thinkpad Configuration”——”Power Management”——”BatteryInformation”——”Cycle Count”, then it will show you
Laptop batteries canfail, or over time can lose their ability to hold a charge. If yourlaptop suddenly stops cooperating, you can usually determine if a badbattery is causing the problem by removing it from its bay (on thebottom or side of the laptop) and running the laptop from the lalptopac adapteronly. If the batteryless laptop runs properly when connected to theadapter, the battery has most likely kicked the bucket, shuffled offits mortal coil, and otherwise become defunct.such as”Dell Inspiron XPS M170 Battery
Dell Inspiron XPS M170 Battery 9 cells 6600MAH
You can further test this hypothesis by substituting a laptop batterythat you know is functioning well from another laptop of the samemodel. You may be able to borrow a coworker’s battery or take thelaptop to a cooperative retailer’s repair counter.
If, in the other hand, your batteryless laptop doesn’t run when connected to the laptop AC adapter, either the adapter or the laptop’s internal electronics have failed. Again, if you can borrow a known-good acadapter, use it to see if the problem is caused by the cords orconverter or if the issue lies deeper within the laptop itself.
How to charge for the new bought laptop?what to do to maintain the laptop battery?
Lithium(hydronium) battery (such as toshiba laptop battery ,compaq laptop battery)needscertain electromotive force inside to keep the activity of internalchemical substances. Therefore, you should charge full and use it up.Generally speaking, the first three charging take about six hours.Charge to 100% is ok then. You should not charge only for a shortperiod of time, when the electric power is less than 10%, charge intime. If you used it up completely, it’ll cause damage to laptop battery; at the same time, if the power is more than 60%, you should not charge as possible as you. The laptop battery which won’t be used for a long, should be used to about 50% power left, and then keep it in room temperature dry environment.
on Feb 23, 2010 | Computers & Internet
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
Dell inspiron 1318 only a year old and battery says its dying, is this an error or do I really have to replace the battery, i do keep it plugged in all the time.
ofcourse the battery will mostly die ina year for most of the dell notebooks.... mainly when u always keep the notebook in the ac power and not using the battery power so much for your notebook...
the best way to keep the battery life extended is to use the battery until it is drained and then charge it and again use it fully until drianed ...
Jul 16, 2010 | Dell Inspiron 1318 Laptop Computer PC...
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
ADAPTER WILL NOT CHARGE MY LAPTOP
Yes, more than likely you will need a new power supply. You can locate them at any computer store.
I hope this solution is helpful. Please remember to rate this solution.
Feb 11, 2009 | Dell Inspiron E1705 Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Dell Latitude D600 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
