Question about Magic Chef Refrigerators
My MCBR1020W 10 cu ft top mount freezer/refrigerator is not cooling correctly. It is -20 degrees in the top and 60 degrees in the bottom. This is a new item.
It is a cheap piece of junk. I bought one just this week and the defrost timer gets stuck so it's going back...........
Posted on Dec 03, 2011
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
Jul 07, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
The temperature is set correctly but the top portion of the refrig does not stay cold (and goes up to 60 degrees) while the freezer gets too cold (and goes to -11). We cleaned the vent on the motor and...
Sounds like the ductwork inside the fridge that connects to the freezer is either partially blocked with ice or the damper flap is stuck in that duct.Please let me know if this helps, a good defrost should cure it if it is
Jan 19, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
We have a 20 cu ft GE chest freezer that will only cool to 20 degrees. What can I check to determine how to fix it?
Please check : - Your door ( gasket /seals, small air leaks) - Refrigerant level - Temperature sensor for failed
Regards,
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
The top section does not cool but the bottom freezer works fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Refrig does not cool to only 45 degrees Freezer is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | GE 18.2 Cu. Ft. Top-Mount Refrigerator -...
The top freezer is working, but the bottom refrigerator is warm, around 58 degrees?
heatman101
Aug 31, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer works even makes ice, bottom 60 degrees
sounds like evaporator is iced up due to problem with the defrost system preventing proper air flow
Aug 07, 2010 | GE 17.9 Cu. Ft. Frost-Free Top-Mount...
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Refrigerators Logo
477 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
