Question about Microtek ScanMaker 9800XL Flatbed Scanner
Noise sound at the end of scanning
I try to scan from Adobe PDF and at the end of scan it doeas a noisy sound like (tak tak tak) and the result is a "black" scan. This scanner is only 3 years old. What can I do?
Thanks.
I Have the same issue, did you figure it out? mines is about 2 years old.
Posted on May 08, 2008
Unable to scan on laserjet m1132 MFP
Hello you have to open the HP LaserJet Scan.
In the HP program group, select Scan to start HP LaserJet Scan
Select a scanning destination
Click Scan.
Here is a user manual in more details:
http://images10.newegg.com/User-Manual/User_Manual_28-115-668.pdf
You need adobe reader to read the content.
Good luck
Dec 31, 2012 | HP LASERJET PRO M1132 MFP
Epson v300
Make sure you have Adobe acrobat or similar installed so that you have PDF available on the PC. It may also be in the software for the Epson. I had a scanner a few years ago whose software excluded PDF and I ended up installing new software of a generic printer / scanner to use Adobe PDF
Jun 07, 2012 | Epson Perfection V300 Film Flatbed Scanner
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
How do I scan and save it in PDF?
Hello and thank you for using Fixya services.
First, scan and save document. Second, download this free neat tool. It will allow you to print as a PDF. When you open the document, you press print, choose cutePDF and it will save the file as a PDF to location of your choice. Hope this helps!
Oct 27, 2009 | HP Officejet 5610 All-In-One InkJet...
HOW I PUT PDF IN MY SACANER
hello,
When you want to scan using the scanning software choose to save in pdf.
Or configure the scanning to save to pdf.
Hope it helps. .
Sep 12, 2009 | Sharp AL-1551CS Printer
System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Dec 18, 2008 | Sharp AR-M205 Copier
Scanning from Canon image runner 2200
You may have to upgrade your adobe
Jul 20, 2008 | Canon imageRUNNER 2200
Pdf automatically opens, then system just hangs
I think the problem lies in your Comp or the Adobe reader. Reinstall Adobe reader, try a later version. Also run scandisk to check if the OS is okay.
S. Mohan
Jul 18, 2008 | Fujitsu fi-5120C
How to add more pages while scanning with Umax Astra 5600
no it is not possible bocz in this tyep model scanner dont have adf (automatic document feeder) it is bettre if you want to scan multiple pager then go for high end scanner model bye
Oct 01, 2007 | Office Equipment & Supplies
Microtek ScanMaker 9800XL Flatbed Scanner Logo
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
