Question about Dell E172FP 17" LCD Flat Panel Monitor
Need to unlock speaker from monitor
I have a E177FP that has a loose power supply cable. I am trying to unlock the the speaker from the monitor so I can soder it.
  • 242 Answers
The E177FP has only a optional soundbar that can easily be separated. Look here.
Good luck
Posted on Mar 30, 2008
6ya staff
SOURCE:
The monitor wont come on.i noticed the power button has been pushed inside the monitor and i need to know if i can disassemble it to get i tout without hurting the monitor
The E177fp and E197fp are identical units other than the size of the display panel. Here is a link to a repair guide for the E177fp that has videos showing how to open the unit. It should help you get your open.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-e177fpf-lcd-monitor-with-power-issues/
Nov 07, 2012 | Dell E197FP 19 inch Flat Panel LCD Monitor
Backlight problems
Yes,
If the capacitors in the power supply are bulging that indicates that they have failed internally and need to be replaced. That would cause the back light inverter to shut down just like you are having.Replace the capacitors and you should be good to go.
BuddyMc
Jul 23, 2012 | Dell Computers & Internet
Have a dell e177fp monitor. When I power on it only displays for 3 seconds and shuts off. Green power light remains on.
You need to check the voltages and components in the power supply/inverter board first. It should have 5vdc for logic and 12~16vdc for the backlight innerter circuits.
There are three version of the boards for this model.
http://lcdrepair.us/Invpowersupply.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 08, 2010 | Dell E177FP LCD Monitor
Power light comes on but screen stays blank
Please try it on another PC first, check the cable also. If it still does not work you decide to DIY repair, please read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Replacement board:
http://www.lcdrepair.us
Apr 20, 2010 | Dell E177FP LCD Monitor
You probably have failure in the inverter circuits due to shorted transistors, bad solder joints, bad caps. Please see my pictures here so you will know what to look for inside.
Replacment board:
Please post back so it may help other people with the same problem.
Apr 09, 2010 | Dell E177FP LCD Monitor
Auto Adjust in Progress
Disconnect the monitors plug. Unplug the power cord. You may not have to do both, but it reset mine and it works fine now.
Oct 20, 2009 | Dell E177FP LCD Monitor
Broken plastic power button
Broken plastic power button? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SED2H 715G1492 2 FR Dell ADTV1742SED2H Power Supply Backlight Inverter...
Apr 29, 2009 | Dell E177FP LCD Monitor
Dell monitor E177FP LCD Monitor
This is normal, typically you must press the power button (on the monitor) to turn it off.
Mar 09, 2008 | Dell E177FP LCD Monitor
Dell 1907FPT lcd monitor
Could be the power supply. Get one at www.partstore.com. I've had very good luck with them fixing various LCD monitors.
Jan 08, 2008 | Dell E173FP 17" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
83 people viewed this question
Ekse
Clive
Clive
Alun Cox
