Question about Fujitsu 24C1 Air Conditioner
Indoor motor starts and stops - Fujitsu 24C1 Air Conditioner
  • 374 Answers
tripping off indore motor is common if the motor develop high current due to obstruction of current flow on the circuit.the overload protection trigger off every time you start the motor.replace bearing of the motor this should be done by certified technician.fix my rate and have a nice day thanks/
Posted on May 14, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
F6 error code on Frigidaire split unit ac, model FSC12CM6J/FSE12CM6J. Solution says to check fuse? Where is this located?
It seems like the indoor fan is not running. Quite a few split systems have a fuse on the indoor board. It will require stripping off the outer cover of the indoor unit and removal of the electronic box cover. The indoor board is in there. The fuse may be replaceable or it may be a type that is soldered on which makes it virtually non replaceable. ( A new indoor board will be required) Make sure all power is turned off or disconnected before you do anything. Another possibility is the fan motor start capacitor has failed. Try this first before stripping the unit. When the unit is turned on and the outdoor unit has started, give the indoor fan barrel a flick with your finger to start it spinning, if it keeps spinning and the error doesn't appear, it would indicate that the fan motor start capacitor has failed. The capacitors on indoor units are normally small black square boxes with 2 terminals on it. These capacitors are mounted inside or close to where the indoor electronic box is. Again, make sure all power is disconnected or turned off at the meter box before you do any disassembly.
Apr 09, 2014 | Frigidaire Heating & Cooling
Inside motor not running and will not run on just fan. cage turns easily by hand
If the out door unit is running without the indoor fan running, you could possibly have a motor burned out or your indoor unit.
If nothing is running, check to make sure all panels are on inside, and that you have electricity to the indoor unit. Some air handlers and furnaces are equipped with a safety switch on the access door to the motor assembly. Also , there may be a switch that looks like a light switch beside the indoor unit.
Once again, check and see if the outdoor unit is running. It will eventually freeze up without the indoor fan. Hope this helps. Please email me if you have any more questions , I will try to step you through. Mark
Jul 11, 2011 | Ruud Heating & Cooling
It starts then stops
As don't mention error code, there are two reasons. If your blower motor working for at least 5 seconds and shut off, Replace indoor coil sensor.
Jan 19, 2011 | Heating & Cooling
I purchased my convair aircon in 04/08. It has been in storage and I have only just started using it. When cooling it starts to cool then starts beeping and has E1 on the display. this can only be...
E-1 Indoor blower motor mechanism locked or Indoor sensor problem. Rotate blower wheel manually. If not rotate, replace bearing. If motor good, replace sensor.
Jan 03, 2011 | Convair Heating & Cooling
My indoor blower is not working it blinks 8 times
This alarm state is a CH08 alarm. Which indicates that the indoor unit fan motor has a locked rotor. Solution is to check the indoor fan capacitor and replace or test the windings of the indoor fan motor. Note: the indoor fan motor is a BLDC fan motor and can not be replaced with any other motor. It runs of a voltage regulated frequency.
Mar 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
The ac comes on but the fan is not turning or comes on
Hi, I assume this is a split system, with the indoor and outdoor unit. If you are talking about the fan on the outdoor unit, this is the condenser fan motor. It is exposed to the heat of the ambient temp. and removing the heat from indoors. If you have a heat pump, this motor runs year around and gets a lot of use. I have seen the 5mfd run capacitor fail which could cause this motor not to start, but more than likely the condenser fan motor has burned out.If it is the outdoor unit you are talking about, can you hear the compressor come on when you start it? You may stand by the unit and have someone turn the t-stat to cool and see if you hear it come on. It will shut off after awhile due to high head pressure. But, if nothing happens, you may not be getting power from the breaker being tripped or a blown fuse at the disconnect box at the unit.Check these before calling out a tech.If you are talking about the indoor fan, make sure the panels are on good if its a gas unit as there is a door switch that is closed and if the panel is loose, it will stop the fan from coming on. The indoor blower motor may also be burned out. It shouldn't take more then an hour at the most to find out what is causing this problem. Could be a fan relay. I would recommend calling a qualified a/c Co. to come out and check this. Wish I was there and could be of more help.
Good Luck, Sincerely, Shastalaker7
Oct 31, 2009 | Goodman CLQ36AR49 Air Conditioner
On my indoor unit the fan just humms will not spin while energize
Did you change the capacitor on the fan motor. Could be bad if not bad fan motor. But sounds like a cap. Russ
Jul 19, 2009 | Heating & Cooling
Fujitsu 24C1 Air Conditioner Logo
65 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
