Olympus Camedia C-700 Ultra Zoom Digital Camera Logo
Posted on May 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i put the memory card?how do i put it in ?and what kind of memorty card do i use?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on May 14, 2010
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428951
Points
622693
There's a door on the right side of the camera (as you look at it from the back). It uses SmartMedia cards up to 1GB in size.
I suggest you get a copy of the manual from http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=677
Can i just install memory and computer configure itself
(1) re-install the memory. or (2) check that computer support 2gb memory, if yes then check the memory bus speed which must be support by computer. if bus speed mis-match then it would not be work. also check memory type. ddr or ddr2 .. and which is your computer memorty slot.
How to download pics from samsung m350 cell memorty card to laptop with usb cable
Connect the usb cable to the laptop,then select the option Mass Storage mode.then that memory card will be shown as a a seperate removable disk,hence you can access your memory card through that disk.
1helpful
3answers
Corrupt memory card
Put it a card reader and format it. That should resolve the problem.
May 06, 2011 • Cell Phones
1helpful
Where can I get a memorty card SD 128 MB for my Kodak Easy Share C 743? Can I also use a larger memory card such as 2 GB or 4 Mb? A. N. [email protected]
You can use SD cards up to 2GB in size. You cannot use SDHC cards bigger than 2GB. You should be able to get SD cards at any office supply or electronics store. You could probably even find them in most supermarkets and drug stores, though they might cost a little more.
Message box keeps blinking at the top right hand corner what could be the problem
its means that your inbox is full with incoming messages,so delete some messages is the solution its actually means that your default message memory is phone memory to avoid such problem in future, and if your phone support memory card , then go to the message settings change the memory option to memorty card from the phone memory....
Put sd card in says no viewable pictures found on memory card
Kindly put in another memory card in the printer .There can be a problem with the memory card picture format.If the issur persists,call kodak @1800 421 6699 .
Can't activate new memory card for my sony camera . how do i
if its original it shuld work properly but if it isnt original then it will do some problem and always but original card but here the solution formate it but not through ur pc but the built in camera option it will help u out feel free to ask again thank u.
I have a new 2 gb dane-elec memory card and when i turn on my camera it says the memorty card is full and when i try formatting it it says filesys error e00100
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Saving emails to lexar memorty stick
Copy and past
You copy the mails and past them on the stick
Good luck to you
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
