Question about KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking
No power light does not come on
Having same problem. I found bad fuse/thermal coupling(I think)
Looked at solution for bad fuse but need more info on part#.
Will continue.
Posted on May 15, 2010
Toaster oven won't turn on...light not on, no heat
check breaker and plug--if power to plug you would need a meter to test the controls and elements for problem
Sep 05, 2016 | Oster Toaster Ovens
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Not heating, but light works? How do I fix this problem?
Your oven is obviously getting power if the light is on. If your heating elements are not getting hot you may have had a switch go bad, a wire come off it's terminal, or possibly a fuse that blew if your unit has one. There is really no way to know exactly where the problem is without taking the unit apart and visually inspecting it. If all the connections and switches look good, some electrical diagnosing is needed to see where the problem is. If you find any wires or switches that have any melted or burned plastic, you will need to repair the connection or replace the switch. If there is no obvious problem, you should have it looked at by a technician who can properly diagnose the unit.
Apr 21, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking Logo
386 people viewed this question
Top KitchenAid Toaster Ovens Experts
Tom Chichester
Bill Boyd
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
