Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer compartment appears not to be cooling, is there a reset button that may restart the cooling unit?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer compartment appears not to be cooling, is - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 14, 2010
Bosch KGU 34640 freezer not cold enough
I had a similar problem a couple years back with my freezer. Behind the vent cover in the back there were a few lines that ran the cooling or something like that. What happened was my freezer was icing up horribly. I was told to take that panel off and check those lines. Sure enough one of the lines was busted through. That was why my freezer was having problems. I apoligize I don't know anything about the front buttons tho.
Dec 28, 2013 | Bosch Refrigerators
Crystal cold lpg fridge the fridge part works fine but the freezer only cools to the same temp as the fride compartment
The freezer should go down to about zero degrees. If your unit is constantly running it is because the internal temp has not activated the thermostat to turn off the compressor. Lower than normal refrigerant levels could account for this. Also to be checked out is the evaporator coil not being frozen over with a block of ice - the latter is caused by an inoperable self defroster - this causes the freezer to not cool properly and raise all internal temps.
If not a self defrosting unit, defrost the unit and restart unit. It will cool properly until the evaporator freezes up again. How fast it freezes up depends on how often the freezer door is opened and how much moist warm air enters the freezer compartment.
Nov 21, 2013 | Refrigerators
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
The fridge compartment is not cooling although the freezer still works. how can i start it working again
you have two nobs. one says to get freezer colder. adjust it back to get your freezer less colder there by making your fridge compartment get mpore cold air. if that dont work then u have a defrost problem.. if that is the case then u have to manualy defrost then restart the unit then if every thing works right for a week or two then u have a defrost problem
May 24, 2011 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
Frost build up in freezer. Causing warming in fresh food compartment. Having to reset unit one to two times a month.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Samsung RF4287HARS. I opened the refrigerator compartment doors and the lights did not come on. Same condition for the freezer. I believe that the unit is operating (as i could hear the faint...
Pc code is saying there was a momentary power loss. Try resetting the control panel by depressing power frig and power freeze for more than 8 seconds. You may have to unplug the unit for 20 minutes if the compressor it very hot and not starting. You may have to depress power frig and power freeze to reset the units control panel to restart the compressor after the 20 min let the cooling system stabilize period.
If after all of this you still have issues with the lights or the unit is not working properly just repsond here and we will help you.
Thanks for Choosing FixYa. Kelly
Sep 29, 2010 | Samsung Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
The fridge part of my fridge freezer appears to have stopped working
Look to the freezer for your problem. Frost free refrigerators are cooled by air from the freezer compartment. If the freezer cooling coil freezes up air flow to the refrigerator is lost. Look for signs of frost on back wall of the freezer section.
Located the defrost timer, turn the clutch head screw clockwise SLOWLY until you hear one audible click. The system will then be in the defrost mode. During the 18-22 minutes of the defrost cycle heaters are energized and defrost should take place. If defrost happens and the timer does not restart into the cooling mode, rotate the screw one more time SLOWLY to the second click and the system will restart in the cooling mode. Replace the timer in this case.
If the timer restarts the cooling after the defrost period and defrost does not happen your problem is in the defrost heaters or defrost thermostat. They are located inside the back wall of the freezer on the cooling coil.
Jul 05, 2008 | Samsung Refrigerators
My american fridge don't appear to be cooling properly and some black stuff keeps appearing in the fridge compartment. it also keeps making rattling noise now and then!! Can you help?
my advice is check and replace the fan in the freezer or the fan blade remove the back cover where the fan is in the freezer the freezer does all the colling for the unit
May 09, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
