Question about Azden SMX10 Microphone
What is the switch in front of the on off switch, the one with the bet and straight line?
  • 4,234 Answers
That is a "rolloff" switch. Basically it is a sensitivity switch for the lower end response. If the mic seems too sensitive to the lower frequencies, put the switch into the position that looks like this: ____
Hope this helps,
Dan
Posted on May 14, 2010
ABS CHECK LIGHT DOESNT COME ON WHEN YOU TURN KEY ON
1. I would not be concerned because if there was a failure in the ABS you would definitely get an ABS warning light and the ABS and most likely the stability control/traction control systems (with added warning lights) will all switch off .
2. You can test if the ABS is operational. On a very quiet damp surface, straight, wide road( with NO other cars around), apply your brakes hard from a very low speed - up to 20 mph ONLY driving in a straight line - until the car stops. The front brakes should attempt to lock up under hard braking and if the ABS is operational you will feel it kick in and the brake pedal will pulsate as the ABS constantly allows brake pressure and then releases it to prevent the wheels from locking up on the damp road. If the ABS does not kick in be ready to release the brake pedal quickly to allow the wheels to rotate so you can steer the car safely. Without the ABS the front wheels should begin to lock up on the damp road surface due to the low level of tire grip. ONLY test this at very low speed and ONLY when driving in a straight line on a straight section of wide road with no other vehicles around.
Dec 15, 2015 | Cars & Trucks
Are there cv joints on the front
constant velocity joints are for front wheel drive cars to transfer the power from the transmission/engine to the front drive wheels that turn around corners , your car is rear wheel drive , rear wheels do not turn around corners so it does not need any type of joints , its a straight drive axle , incidentally your car has the 3.o jaguar engine id bet since they were a deal ford did when obtaining jaguar (let them use them in there lux cars)
Jul 22, 2015 | 2001 Lincoln LS
I have an RCA television (Model #: F27443). I need to change the tv/video to video, but I don't have a remote. Also, there is no button for tv/video on the front panel for this particular model.
Hi - Push the leftmost button on the front panel, labelled Menu. Go to "list and labels." I'll bet that you will find that the inputs have been switched off. Switch them on and they will appear in your normal channel line-up.
Feb 26, 2011 | RCA F27443 27" TV
Front air bags keep going down we replaced a cylanoid in the front lines and that was not it any guesses?
Spray Windex on the lines and connections and I bet you will find the leak. Air coming through the Windex will produce bubbles.
Feb 10, 2010 | 1996 Lincoln Mark VIII
I have a 19996 dodge ram .whent to the snow the other day and the frot axle would not lock in and no 4 wheel light on the dash. any one know what could of happened was working right be for whet to the...
it has a vacume actuator,check vacum line,with switch on or shifter in 4x4,depending on which one it has,you shuld be getting a vacum to the actuator on top of the front axle,if not the plastic line is broke somewhere,engine might miss a little,if you have vacume the acuator might be bad,I will bet its in the plastic line
Jan 30, 2010 | 1998 Dodge Ram 1500 4WD
Noticed the brake light was alwasy on where are
There is a switch on the handlebar brake lever and a pressure switch somewhere along the metal rear brake line. Since they change the location of this pressure switch from time to time and I don't know exactly where it is on your bike, just follow the metal brake line that comes out of the back of your rear brake master cylinder. You'll recognize it when you see it. It will have two or four wires connected to two spade plugs.
If I were a betting man, I'd bet that someone at some time has loosened the master cylinder on the handlebars to adjust something or taken the throttle switch housing loose. The front brake light switch in located inside the throttle switch housing. If the master cylinder and the switch housing are not firmly pushed against each other, the brake lever will not depress the front brake switch when your release the brake. This will cause the brake light to stay on all the time. Loosen the master cylinder clamp bolts and slide the master cylinder and brake lever snuggly against the face of the switch housing. This will probably fix your problem. If not, you'll need to do a little electrical troubleshooting to determine whether the front brake switch or the rear pressure switch is bad. For this, you'll need a Volt Ohm meter and a wiring diagram.
Try the switch first.
Oct 19, 2009 | 2008 Harley Davidson FLHX Street Glide
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Three straight lines on display.
Open the door, and in the gasket is the light, tighten it. All should be good.
Sgt 48
Mar 24, 2008 | Miele Touchtronic W1213 Front Load Washer
Our topload Kenmore Elite washer will not fill with water. It starts to agitate right away upon setting the dial
try switch in the load size?? sounds like your having a problem with the pressure/ water level switch. it must think its full of water already. you would need to pop open the control panel. either 2 screws located on back of console (while looking over the top of machine and straight down you should see 2 Phillips head screws in both corner of top screwing straight down. if not the 2 front end caps will pop of control panel to reveal the screws. undo the screws and tip the console back( its hinged), the far left is the pressure switch, it has a clear plastic tubing leading to it. remove the tube and try blowing through it(clear the line) try also blowing back into the switch itself you should hear it click. if after that it still doesnt work id say the switch is no good
Mar 14, 2008 | Washing Machines
Azden SMX10 Microphone Logo
49 people viewed this question
Top Azden Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Azden Audio Player and Recorder Expert? Answer questions, earn points and help others
