Question about Abit KN8 SLi Motherboard
Red light on motherboard , power comes on but computer dont boot up
  • Jose Deleon May 14, 2010
    does it beep? does it show an error message?
    Problem Solver:
  • 16 Answers
Sounds like you connected your front panel wrong. check to make sure all of the connectors on your board on where they need to be.
Posted on May 14, 2010
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
The computer does not boot up at all nothing comes up on the screen I have changed the power supply and the ram also disconected all the hardware and still no boot up. what do you think john
i think we should troubleshoot part by part. i wish it could give some beeps or error messages if not so. its going to be hard but hope we will get the course.
in this process you need to be so carefully so that we dont end up havong other issues.
1. check if the power inters the board(mostly there is a blue light inside the computer that lights; check that) if yes go to 2 if no go to 3
2. issue that the computer switch is connected well.if yes go to 4
3. the power supply does not power the board(troublshot the power supply)
4. check the vidio display. issue the lights on the keyboard.
please let me know. you can also call me on +256704008988
or send me your number
Dec 07, 2009 | ASUS P4S533 Motherboard
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Aug 03, 2009 | Gateway MT6840 Notebook
Computer wont Boot up normaly
first romove the power cable. then remove the ram, then remove the agp or pci express if you have. Then adds this thing together. add power cable.
Start the computer.
Jan 21, 2009 | Gigabyte GA-8I848P-G Motherboard
Motherboard won't boot up
Hey there,
This causes if you havnt connected the power cable coming from th power button to proper jack or pin.
Check out the pin in which ur power button cable is inserted.
Does your system boot when u press the restart or shut down icon from ur windows (OS). If it is not letting ur system to boot then you've been attacked with the Worm viruses. These viruses dont let ur system to boot because they keep their process running untill ur power is off.
Gimme ur acknowladge by rating me.
Thanx.
Romy
Dec 24, 2008 | DFI LANParty UT RDX200 CF-DR Motherboard
Fic k7mnf-64 motherboard socket 462 amd 3000+ When I plug the computer in all that happens is a red light on the board comes on and a buzzer goes off.
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
Dec 18, 2008 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
No boot No fan noise no display but lights come on
Somethings has happened to your motherboard, CPU and/or hard drive somewhere along the line if it wont power up when you hit the power button and this would explain the reason for no activity. When a motherboard fails, no activity will happen at all, so Im putting my money on your motherboard being defect so take it in for a service and you may have to buy a new laptop since repairs can be costly.
Nov 20, 2008 | Computers & Internet
Blinking red light at "on" button
Dont panic the date is more than likely fine was the computer off or on during the night. The three flashes is usual joined with 3 beeps chweck that the internal speaker is on. Second there is a small battery on the motherboard. Disconnect the power then take the battery out for twenty seconds then put it back in be gentle taking it in and out the reconnect the power then see if the unit boots if not. At worst you can take the hard drive out of the computer and put it in another and retrieve the data.
Hope this helps :-)
Aug 15, 2008 | HP Compaq Business Desktop d330
Neoware Red light power
Power Supply is Shot...I've been working on literally 30 of them for my company....I'm not happy. If you know of any company who will be willing to sell them. Please tell me. HP wants $50 to Fix Just the Power Supply Board
Jun 08, 2007 | WYSE Wall/VESA Bracket Kit, for Select...
Abit KN8 SLi Motherboard Logo
455 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
