Question about Motorola Walkie Talkie 2-Way Radio
I have a motorola xts 2500 800 mghz. Im gettin a circle with a line through it symbol on the dispay on 1 talkgroup only and getting a "key fail" when I push to talk. Any ideas?
  • Motorola Master
  • 1,654 Answers
The circle with a line through it emblem indicates your radio is scrambling the channel chosen. Your key fail message likely indicates your radio has a programming problem or other problem requiring dealer assistance.
Best regards.
Posted on May 16, 2010
  • motomp Sep 09, 2010
    "KEY FAIL" Simply means your encryption board has lost it's programming, or "KEY LOAD" It's not really a problem, or a malfunction, the radio is not programmed for infinite key retention , so as soon as the battery is removed from the radio, the keyload erases. This is done so that if the radio falls into the hands of the enemy,(YOU) they cannot listen to encrypted transmissions.
How do I type in symbols that don't exist on my key board, in so can I send you a picture to identify gun SN?
If the following line works, it should appear as a triangle/upside down pyramid
<p>&#8711</p>
The link to instructions is here:
HTML Symbol Entities Reference
Sep 23, 2014 | Military Collectibles Mannlicher Military...
Key fail for motorola xts 2500
Sometimes portable radios forget their encryption keys, especially when it takes you longer than 30 seconds to change a dead battery. You may have to either re-flash the key into the radio or else change the software setting from security hardware equipped to NOT security hardware equipped, or else just ignore the key fail warning and realize that your transmission is no longer encrypted like it used to be.
Oct 25, 2011 | Motorola Walkie Talkie 2-Way Radio
I use a Motorola XTS 5000 2 way radio at work. It displays a message "Key Failure"' and intermittenly beeps. It will not allow transmissions. Can I program a fix or does it need to be repaired?
It needs to be looked by a programming technician in a radio shop. "Key Failure" means that a secure encryption key has not been loaded into the radio and you have set the switch for using encryption to the "on" position. This switch is located under the channel switch on top of the radio and in your case it should be set to the "O" position and not the "O" with the line through it. The XTS radios can be programmed to retain the encryption key when the battery is removed OR to keep the key even if the battery is removed, so it depends on how your radio was programmed as well.
Mar 25, 2011 | Radio Communications
Bleed over to other channels
When you make an announcement, It wil overide other normal traffic, Announcements take priority. Assuming you are useing a 6809 controller. Look at the announcement talkgroup, with your RSS or use CAS to look at the 6809.
Good Luck., Bill
Aug 27, 2009 | Radio Communications
IBook never completes loading, stuck at ble progress bar
I am running off memory, but I belive you can also hold either Option or Command key at chime startup and it will give you a visual option with booting to hard drive or disk drive.
Try that and see if it will show the option to boot from CD.
I would suggest probably reinstalling OS X
Jul 16, 2009 | Apple iBook G3 Mac Notebook
Symbol LS7708 - "enter" key programming
You will have to set up a new Suffix -- the ASCII suffix for a "field exit" is 7009. You can contact the Symbol/Motorola Help Desk at 1-800-653-5350. Have you manual handy. If you don't have a manual, download one at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=6953101apdf&sliceId=&dialogID=118614144&stateId=1%200%20118568992
Cheers...
Billy Barcode
1-866-306-7226
Apr 15, 2009 | Motorola Computers & Internet
A symbol on my dash board...
  • wrong key! you may need to go and get a key made from the dealership it cost $40 try this first!!
Mar 27, 2009 | 1995 Jeep Grand Cherokee
Increase in memory channels
Do you have an FCC License to transmitt on this radio?
Modifications to this type of radio are only authorized by an Authorized Motorola Service Facility.
Check your local phone book for Authorized Service Centers.
Sep 11, 2008 | Motorola Radio Communications
Radio Communications Logo
529 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
