Question about Amana ALG331RAW Gas Dryer
My dryer is not igniting. I replaced the igniter, still wont heat
My dryer is not igniting. I replaced the igniter and still nothing. The igniter glows but does not light the unit. What is the problem?
  • 619 Answers
The ignition coils located on the gas valve or the flame sensor located on the burner assembly is the problem. Both inexpensive repairs.
Posted on May 14, 2010
Workes fine no heat
the temperature thermostats and or heater are bad, on electricdryers, you can ohm out to see what is defective.
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
electric dryer
1 Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
2 Thermal fuse
Oct 27, 2009 | Candy CDC266 Dryer
I have a lgr4634jq1 gas dryer flame wont stay lit runs but no heat
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 09, 2009 | Whirlpool Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Aug 11, 2009 | Kenmore 73952 Gas Dryer
Turns on but wont heat up
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 13, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Alg331raw gas dryer. Runs but no heat. Worked
Check the following to address this issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 04, 2009 | Amana ALG331RAW Gas Dryer
Kenmore 70 series dryer wont heat up and wont stop running
For a gas dryer, check the following
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electric dryer, check the following
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
3. Thermal fuse
Jun 01, 2009 | Kenmore 63942 Dryer
It wont dry my clothes
Check the following for a gas dryer--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Check the following for a electric dryer--
2. Heating element
3. Thermal fuse
Jun 01, 2009 | Kenmore Dryers
Dryer not heating
For a gas dryer, check the following---
1. Gas valve coils
2. Thermal fuse
3. Igniter
For a electrical dryer, check the following---
2. Heating element
3. Thermal fuse
May 31, 2009 | Whirlpool Dryers
Kenmore cloths dryer will not heat up
3. Igniter
Oct 18, 2008 | Kenmore 659 Electric Dryer
Amana ALG331RAW Gas Dryer Logo
686 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
