Question about Microsoft Xbox 360 Console
I can hear my xbox 360 but the picture isnt showing up on the tv
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 60 Answers
Check that your color cables are secure in the tv... Possibly your audio is in securely but you need to tighten the picture one.
Posted on May 17, 2010
My xbox 360 doesnt seem to be giving a picture on the tv, it isnt the scart lead but when i shake the 360 slighly i can hear something moving around inside like theres something loose
I would say take the front off and look for a loose wire, and if you do find one try to find something that looks like there should be something connected to it and there isnt and connect them then it might start working again. But be careful and were rubber gloves, I dont want you to get eletricuted.
May 06, 2010 | Microsoft Xbox 360 Console
The picture doesnt show but I hear the sound.
Don't worry the HD feed from the xbox 360 has a gain limiter
So the chances are more likely that either your Friends xbox has
the HD setting off or the TV has defaulted to standard video in.
If you get a black screen or a mesage that says no single .
But if your getting strange color on your set with the HD on
then we need to investigate this " Microsoft is liable!" for
damages caused by their console. Ill look in to this and
follow up. The xbox has broken connection under the poorly
soldered G.P.U. and will need to be re-flowed to the main
board to corrects this problem but that's a secondary priority
right now.
I'll check this out for you and follow up.
Rob
Oct 03, 2009 | Microsoft Xbox 360 Console
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Showsno picture but can hear it
I need more info, are you runnig High Definition? Are your cables connected properly? Is your TV working properly?
If you're running on a Standard Definition TV check the back of the Xbox and see if the video switcher says SD.
Jul 26, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
No picture
it could be that u r not hoooking it
Jul 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
52 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
