Question about Lexmark X5470 All-In-One InkJet Printer
How to print front and back
Steps on how to print front and back
    Novelist:
  • 107 Answers
Dear Sir,
I think you're talking about double-sided or duplex printing. If so, you should be able to this through the Print dialog:
1.Press CTRL/P.
2.Check the Manual Duplex checkbox. This will cause Word to print one side of the sheets, then tell you to put the paper back in so it can print the other side.
Hope that helps
Posted on May 14, 2010
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    I have an HP C-4480 printer and I would like to print from front to back. I found a place to check to print front to back but it doesn't work. Everything always prints back to front.
    Please follow the steps listed below and enable the front to back option.
    1. Click on the start menu.
    2. Clikc on the printers and faxes folder
    3. Right click on the Office Jet 5600 series.
    4. Click on the "general" tab.
    5. Click on the printing preferences under the general tab options.
    6. Click on the basics tab and check the front to back option.
    Jul 18, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
    Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
    FLOWO THE STEPS
    1. 1
    Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
    2. Step 2
    Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
    3. Step 3
    Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
    4. Step 4
    Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
    5. Step 5
    Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
    6. Step 6
    Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
    7. Step 7
    Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
    Apr 25, 2010 | HP PSC 1610v All-in-One Printer
    It wont print
    1. 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    Apr 22, 2010 | Brother HL-2040 Laser Printer
    When trying to print the printer pulls in more than 1 sheet of paper causing a jam in e.ta
    just folowe the steps
    1. 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    Apr 21, 2010 | Epson Aculaser C1100 Printer
    Keeps saying there is a jam in the paper feed, when you open the front door there is no jam, reclose it and it will print
    1. Step 1
    Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    2. Step 2
    Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    3. Step 3
    Look for paper through the opened back panel. Remove any paper you find jammed.
    4. Step 4
    Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    5. Step 5
    Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Step 6
    Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    7. Step 7
    Close the front access panel. Make sure that it latches back into place.
    8. Step 8
    Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 17, 2010 | HP LaserJet 2420 Printer
    Paper jams /canon480
    Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  • Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Jan 26, 2010 | Office Equipment & Supplies
    Printer wil print when scanning but not from computer
    There are a few steps you will need to follow to resolve this problem. Follow these steps one after the other. start with the first step. after each step, try to print and see what happens. if your problem is resolved, ignore the other steps.
    Step one: Clear any paper or carriage path obstructions
    1.
    With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2.
    Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3.
    Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4.
    Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
    You may have to reach through the output paper tray to access the print carriage.
    5.
    Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6.
    Press the On button to turn on the product.
    Step two: Ensure correct installation of the front panel overlay
    If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below.
    If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
    NOTE: If you have already installed the front panel overlay, proceed to the next step.
    1.
    Disconnect the power cord.
    2.
    Locate the front panel cover and peel off the paper backing to expose the adhesive as shown in the graphic below.
    3.
    Lift the scanner lid and carefully line up and install the front panel overlay.
    4.
    Plug the power cord in.
    5.
    Try the print job again to see if this step resolved the issue.
    If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    If the issue is not resolved , continue to the next step.
    Step three: Plug the product directly into a wall outlet
    Verify that the product is properly connected to a suitable power source by following the instructions below.
    1.
    Verify that the computer and the all-in-one product have a three-prong power plug.
    2.
    Unplug the power cable from the back of the all-in-one.
    3.
    Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
    4.
    Plug the power cable into the back of the all-in-one.
    5.
    NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
    Step four: Perform a partial reset
    A partial reset will return user settings to factory defaults. you may have, language and country/region settings also resetted. Perform a partial reset of the product by following the instructions below.
    1.
    Unplug the power cord from the unit.
    2.
    Reconnect the power cord into the unit.
    3.
    When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
    4.
    When only the On/Resume light is flashing, release the buttons.
    When the On/Resume light is steady, the reset is complete.
    5.
    Step five: Remove and re-install the print cartridges
    Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
    1.
    With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center.
    The print cartridge carriage is the plastic part that holds the print cartridges.
    NOTE: If the carriage does not come to the center, try turning the printer off and on.
    2.
    When the carriage is at the center of the access area, unplug the printer.
    3.
    Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
    NOTE: Try to inspect and reinstall the cartridges as quickly as possible, so that they do not dry out. Avoid touching the copper-colored parts of the cartridge.
    4.
    Reinstall the print cartridges.
    The black or photo cartridge goes on the right.
    The tri-color cartridge goes on the left.
    5.
    Close the cartridge access door, plug the printer back in and turn it on.
    6.
    Step six: Service the product
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    May 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
    I have an HP Officejet Pro L7580 and for some reason it is printing back to front. The only way to read it is to put it in front of a mirror. Can you help?
    1. Go to the HP print settings box.
    2. Click File and then click Print .
    3. Click Properties , Setup , or Printer .
    4. If you still do not see the box, click Setup , Options , or Properties .
    5. -OR-
    6. If Print is not there, then click Printer Setup or Print Setup .
    7. Then click Setup or Options .
    8. In the HP print settings box, click the Features tab, and then uncheck MIRROR . Click OK .
    try this steps and send me feedback to give you further troubleshooting steps if needed..
    Sep 01, 2008 | Office Equipment & Supplies
    Lexmark X5470 All-In-One InkJet Printer Logo
    339 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
