Question about AT&T Blackberry Curve 8300 Smartphone
I have a Blackberry 8310 and I have just got a strange symbol appearing in the upper right hand corner. It is rectangular with white stars going diaganally separating the box into two colours blue and black, how do I get rid of this, as I cannot receive or send calls..
  • geogheganmst May 14, 2010
    Responses was quick and professional, even if the solutions did not fix my problem, as now need to go to provider.
    President:
  • AT&T Master
  • 2,923 Answers
That icon is the Enhanced Call Audio. It will appear when you make or received calls. There's a possibility that the phone is stucked in call state.
Press "L" three times. And that should dismiss it.
Thank you and good luck!
Posted on May 14, 2010
  • 2 more comments
    Hello, I have pressed the letter L three times by hold down the Cap button and the symbol is still there, any other suggestions?
  • Melvin Ramos
    Melvin Ramos May 14, 2010
    Try this:
    Press the BB key, select Options, General Options, and set "Enhance Handset Call Audio" to Normal.
    If that did not help, remove the battery while your BlackBerry is turned ON. Leave the battery out for 5 minutes, then put it back in.
    Thank you!
    sorry about this, I have turned the Enhanced Call Audio to Normal and it is still the same. I have taken the battery out twice now for 5 mins and the same....I can get icon to disappear but the same noise when I make a call as if icon still there, it has a constant click, click noise when I make or receive a call that also creates gaps and I cannot hear caller and they cannot hear me amid these gaps and click noises.
  • Melvin Ramos
    Do you have any important files in your phone? I would suggest for you to back up the files using the BlackBerry File Manager (so that you could have a copy of those important files), and then completely wipe your BlackBerry. After that, you can restore those files back to your BlackBerry.
    I checked some forums that it seems that this is an on-going issue with some BlackBerries. If same problem occurs after wiping the BB, contact your wireless provider to verify the issue.
    Thank you!
"When I try to sinc my blackberrycurve to my
Try these simple steps: 1) Disconnect your Blackberry from your computer 2) Start DM (Desktop manager) and on the upper right hand corner select Options 3) Select "Data Folder Options" 4) Choose "Use this specified folder" 5) Right click the data path and hit "select all" and copy 6) Hit Start and select Run 7) Paste data path into run and hit ok 8) Blackberry folder should open up 9) Find the "Intellisync" folder - select it and delete it 10) Connect your Blackberry 11) Go to your DM's main menu - select "Synchronize" 12) On the left hand side - select Configure Synchronization 13) Press "Synchronization" button 14) When done - select Synchronize (Upper left corner) 15) On the synchronize screen - select only "Synchronize Organizer data" and "Update device date and time" 16) Select "Synchronize"
Jan 06, 2011 | RIM BlackBerry Curve 8310 Smartphone
Strange symbol on screen of my blackberry pearl
Generally rectangular box appears when you are in Roaming. After doing the Hardreset still if you are getting rectangular box in your handheld kindly walk into the nearest service center.
A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
I hope I was able to help you.
Thank you for using Fixya.
Nov 13, 2009 | RIM BlackBerry Pearl 8100
8310 BlackBerry start-up symbol
you must fullflash your BB to work it again.you can use desktop manager 4.7 to flash your phone.
and here you can download firmware:http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Jul 25, 2009 | RIM BlackBerry Curve 8310 Smartphone
My phone screen went out
call in warranty, t-mobile should have a one year end user warranty. as long as there is no water damage you get a new one for free!
Jun 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
Unknown icon
I had the same problem for awhile too.
The box is your call equalizer settings.  The descending line indicates "boost bass" and the ascending line indicates "boost treble"
This usually only shows when you have your BB headset connected, to change the settings:
-plug in your headset -make a call, (voice mail works good for this) -press your menu button -select "Enhance Call Audio"
-make your selection
You'll see your choice on the screen
Let me know if this helps 208E019D
Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bad reception on my blackberry pearl.
that triangle means you have activated your roaming feature on your phone......so you should contact or visit your carrier and have them deactivate it for you.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Every time I make a phone call My blackberry has a strange symbol
The icon is an indicator for the Enhance Call Audio feature selected on the device. The Enhance Call Audio feature is designed to allow a user to adjust the sound quality over the earpiece of the device (e.g. Boost Bass or Boost Treble)
To improve sound quality for all phone calls, complete the following steps:
  1. In the Phone application, display the menu and select Options.
  2. Click General Options.
  3. Change the Enhance Handset Call Audio or Enhance Headset Call Audio field.
  4. Display the menu and select Save.
To improve sound quality during a phone call, complete the following steps:
1. During a phone call, display the menu and select Enhance Call Audio.
2. Select Boost Bass, Boost Treble or Normal.
To review the different Selectable Phone Equalizers during a phone call, press the L key. The enhancement specific icons are displayed on the active call screen.
Typing on my blackberry
It sounds like you have alt or sym function on which is turning your inputs into numbers and symbols. You will have a logo in the upper right hand corner showing you which feature is activated. Turn it off.If you are unsure what I am referring to in turn turn press ALT twice and watch the logo in the upper corner, turn it off and do the same with SYM. You should be able to use your keyboard as normal now.
Feb 12, 2009 | RIM BlackBerry 7290
Strange unkown icon
This appears when you have received a blackberry messenger message. To view this goto the main menu and got to the blackberry messenger icon (blue blackberry symbol speech bubble icon)
Dec 18, 2008 | RIM BlackBerry Curve 8310 Smartphone
This phone is a blackberry curve
when the blackberry curve battery gets low it will disconnect its own radio signal you have to restore the connection when ths happens all you have to do is try to make a call the phone should then tell you the radio is not connected it should give you the option to restore the connection
Nov 10, 2008 | RIM BlackBerry Curve 8310 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
57 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
