Question about Frigidaire ATF6000ES Front Load Washer
A error code 20 comes up what does that mean?
  • 35 Answers
It's actually a drain problem. Remove the front kick plate and locate the pump. There is a flexible rubber trap attached to the pump and line by two hose clamps. Remove, clean out and replace. It's a stinky job, but you will be amazed at what you will find. This should solve your problem!! Good luck.
Posted on May 14, 2010
What is code blinking 20 on noritz tankless hotwater heater N_069M
The error is a HIGH LIMIT THERMAL ERROR. That means Calcium buildup has appeared in the unit. It is also called scale. To clear the error you have to power it off. That is done by the circuit breakers. You should descale the unit first though.
Jul 26, 2014 | Noritz Water Heaters
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
Error code F-20
WHAT DOES ERROR CODE F-20 MEAN
Oct 03, 2012 | Whirlpool WFW8300SW
The computer panel says f 20, what does that mean?? And when I turn the washer on, I noticed that no water is going into the machine?? why??
The error "F20" means : Water Inlet Problem - no water or insufficient
water supply.
Several possibilities.
Have a look at this forum - several tests must be perform to clearly identify where does problem comes from :.
http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/10201-fixed-whirlpool-duet-sport-f-20-error-code.html
Good luck
Jan 24, 2011 | Whirlpool WFW9400S
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
Error code
sure is it e4 20?
or maybe e3 20?
if this error alway displays, it means that your machine is having problem with main motor rotation, pls contact your service provider.
May 23, 2008 | Panasonic DP-6010 All-In-One Printer
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Frigidaire ATF6000ES Front Load Washer Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
