Question about Estate TEDX640JQ Electric Dryer
Drum not turning
Estate Dryer TEDX640PQ ser MT1744900 it has heat but the drum in not turning, humming nothing we are looking for a wiring diagram.
  • judirexw May 15, 2010
    Thank you so much to localwonder for all his help and the fact he stayed online with me last night while I ran back and forth with messages and questions. It was the thermal fuse on the blower housing and I am back in business...ty again.
  • 6,784 Answers
Hi. Your symptoms are a very strong indicator of a failed rotating motor. If the drum cannot be rotated manually, or if it can be rotated, but with great resistance, this will confirm the problem area. Use my motor testing procedure to confirm once more with accuracy.
Locate your dryer motor. There will be two wire leads connected to the motor. Disconnect the motor's two wire leads from the wiring harness. Set your multimeter to the R x 1 setting. Touch each of the meter's probes to one terminal each. Your motor should show little resistance (a reading of zero, or close to zero).
Now check the ground connection. Place one probe on the bare metal housing of the motor. Place the other probe on each terminal, one at a time. You should not receive any reading on your meter from this test.
If your units motor fails either of these tests, you will have to replace it.
Additionally, if the motor passes the test, the culprit will more than likely be the door switch. i suspect a failed motor.
Concerning the wiring diagram for this unit:
It dose not exist in any data banks i have search through at this time. It may be possible to contact the manufacture for what you seek. I can only post exploded unit diagrams for your unit, at this time.
Posted on May 14, 2010
  • 16 more comments
  • Michael Masters
    Michael Masters May 14, 2010
    • I would also advise to inspect the drive belt for signs of old age or stress. Replace if needed.
  • judirexw May 14, 2010
    the drum turns freely...and the belt is in great shape...he is checking the motor how you suggested now..I will let you know. If the motor was going out shouldn't it have given some notice?
  • Michael Masters
    It all depends on how it has failed. If it was windings failure, this is usually a silent progressive issue that will cause unexpected failure.
    Hi he checked and the motor is giving him a good signal but he believe the fuse there? is blown would that make it not work? Sorry to be so spacey trying to read your stuff to him and ask his questions of you and running back and forth..
  • Michael Masters
    There are only two fail points in this situation. It Will be either the door switch or a failed rotating motor.
  • Michael Masters
    Absolutely, if that fuse has failed, the motor circuit will not be energized correctly.
    well I am going to try to purchase the fuse from the dealer here in our town...I won't close this until I let you know if it worked ty so very much.
  • Michael Masters
    A simple continuity test on the affected fuse will confirm failure at the fuse.
  • Michael Masters
    Sure, no problem. I will be waiting for your response.
    Yes he tested that area of the fuse and there is no reading. He is a mechanic on oil rigs but this has him baffled. I will let you know after we get the fuse in. Hope that is what it is I don't want to replace the motor. have a nice evening.
    He wonders if you can wire around the fuse to be sure?
  • Michael Masters
    Ok.
    Have a nice evening yourself, and i will be standing by for further discussion, if needed...
  • Michael Masters
    I do not recommend that. This will cause an extreme reaction if there are circuit issues concerning the main control sector. Normally when a fuse burns out, it will be the result of age or preexisting issues within the door switch or control sector.
    It is possible to jump the fuse circuit, but i don't recommend it.
  • Michael Masters
    Bad terminal junction points or loose power cord connections will blow fuses as well.
    Ok I will STRONGLY suggest he not do that...ty
  • Michael Masters
    Ok.
    Just wanted to let you know it was the themal fuse...got a new one popped it in and we now have a running dryer...ty for your help...have a great weekend.
  • Michael Masters
    Michael Masters May 15, 2010
    That is great news:)
    Have a great weekend, and god bless..
My dryer has heat but does not dry
is the drum turning? if not you must replace the strap that turns the drum. if it is heating and the drum is not turning , that could cause a fire.
Sep 30, 2014 | Estate by Whirlpool EED4100XQ Estate...
Dryer is heating but not turning making noises from control switch even in off position
That's a plain jane timer on that dryer. The motor probably has a stripped gear in it. Seen it.
Nothing in the dryer would cause this timer to make noise UNLESS the RH terminal was arcing while in the heat mode of the timer setting. The result over time would be this:
I would say you is in need of a new timer. This timer has feature which advances the motor only when the heater is not on using this orange wire to feed back to the timer motor:
That is the middle wire on the high limit.
To replace the timer yank the knob straight off and remove the screws. Pay attention to how the wires connect. Pretty simple fix.
I have a manual and more service photos HERE
Mar 19, 2011 | Whirlpool TEDX640PQ Dryer
Trying to find out how to get to drive motor and belt estate tedx640pq-
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Oct 17, 2010 | Estate EED4100SQ Electric Dryer
Air blows drum turns but no heat in dryer
Your heating element or thermal fuse are bad. These are reasonably easy fixes if you need a step by step just let me know.
Aug 26, 2010 | Whirlpool TEDX640PQ Dryer
I have an estate TEDX640PQ0 Dryer that won't get hot. I Replaced the heating element but still nothing
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Whirlpool TEDX640PQ Dryer
My Whirlpool Estate: Model tedx640jq1, stopped working in the middle of a load and now will not start.
i would check the door switch, part #3406104 and the drum belt part #8066065. hope this helps.
Nov 13, 2009 | Whirlpool TEDX640PQ Dryer
This is a Estate (Whirlpool) Dryer. My son turned
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 06, 2009 | Estate Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Drum will not turn
YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
RODNEY
May 15, 2009 | Estate TEDS740JQ Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Estate TEDX640JQ Electric Dryer Logo
54 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
