Question about Honda Landa PG 3500 PSI Pressure Washer
Soap intake not working i use the black tip but niether one of the machines wont **** the soap plz help thanks dan
Remove brass fitting from pump and soak in lime-a-way for 24 hours
Posted on Aug 02, 2010
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
Honda lifter
I assume you are talking about the chemical intake tube... Most commonly you would see one end of the tube attached to the small tapered nozzle on the pump, and the other end which should have a small filter attached to it - is what you would submerge in a container of soap/degreaser/chemical solution of your choice.
If you have it set up in this way you will get the addition of whatever soap product you have the clear tube sitting in mixed into your spray stream. -- it's important to note that you will only get suction and soap flowing through if you are using the widest (black) spray tip. With the broad spray tip on you can get soap flowing either with or without the engine running - which can sometimes be helpful if you have to be careful of what you get the soap on.
Mar 21, 2014 | Honda Garden
What causes black grease in soap dispense in my front load GE washer
Possible that this could be due to accumulation of dirt and so a good clean up of the washer might help/
Please check this link for tips: Cleaning
Feb 27, 2013 | GE Washing Machines
Chemical wont siphon
In most cases this is because you have a high pressure tip, the red, white, yellow or green tip, on the wand. The detergent system will only work if you have the black, soap tip on the wand. With a pressure tip on the wand, there is too much back pressure for the syphon system to work. If you are using the soap tip, check the feed tube for the detergent for blockage, especially at the pickup filter and where it attaches to the water line.
Sep 16, 2012 | Powerboss 020309 3000 psi 2.5...
I have a karcher 3000psi 2.5GPM.Is not vaccum to bring the soap in the water line. Thank. Ed
Some soap injectors have an adjustment that must be turned to allow or increase the amount of soap that enters the line. To make it work, install the blace tip on the wand (black tip has a very large hole/nozzle). With the black tip installed there will be very little pressure in the discharge hose and soap will enter. If your machine does not have an adjustable injector you dont need to do anything for it to work. If soap does not enter, stop enging and turn off water. Remove the injector fitting and check for debris. There is uaually a spring and checkball (very simple design).
Oct 10, 2011 | Karcher G3025OH Pressure Washer
Central locking not working niether is my electric windows or mirrors can you help me plz
The Fuse panel Is inside the DRIVES side.
Open the Driver door. Look at the side of the DAShboard.
THat Giant "B" Shapped plastic cover pops off.
Check the fuses...IF any are broken,black or no good.
REplace them
Hope this helps
Sketchlab.com
MugShot Collection
Apr 26, 2009 | 1999 Volkswagen Passat
The machine wont take the fabric softener.
Remove soap drawer from washer, and remove all accessories,and thoroughly clean all parts, particularly the conditioner parts, make sure the syphon tube is clear by poking through it .
Clean interior of soap drawer compartment with a stiff nylon brush or similar.
Plz rate my solution.
Thanks.
Jan 23, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Colour problems
the same for me with black ink .....
Thanks
Phil
Dec 18, 2007 | HP Photosmart 2610 All-In-One InkJet...
Honda Landa PG  3500 PSI Pressure Washer Logo
231 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
