Question about Wells F-686 Deep Fryer
Wells 35lbs fryer double vat
My deep fryer will continue to heat past set temp and boils over. left side works great. Could it be thermocoupler or control unit
  • Anonymous Mar 26, 2014
    fryer has been on for hours and seems to be boiling yet gas keeps turning on and off . It doesnt go to ready.
    Champion:
  • 254 Answers
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Posted on Jun 03, 2008
SOURCE:
Replaced the thermostats and high limit switches on both sides of a double vat unit. One thermostat blew immediately when the power was turned on. Blew like burned the guts out of it. This side is now dead...
Hi there, it seems that the wiring is messed up. For wiring diagram, you may visit www.wells-bloomfield search for your fryer model and you may be able to download it free.
Jan 30, 2014 | Wells F-67 21167 Deep Fryer
Imperial cif 40 single tank bouble basket deep gas fryer
When the whole unit shuts down including the pilot light the thermocouple is not working properly. The thermocouple is what tells the gas safety valve that the pilot light is lighted. When the thermocouple fails and does not send the milli-volt (mv) signal to the gas safety valve due a failure the gas safety valve turns off the gas supply. (i.e total shut down)
If you have a handyman around you can have him disconnect the thermocouple from the gas valve control and clean the mating area in the gas valve and on the bitter end of the thermocouple. After cleaning then reconnect the thermocouple. This sometimes corrects the problem. FYI you can get a thermocouple at most any large appliance parts supply. (You will need to the know total length) It would be even better to have the old one in hand during the trip to the parts store.
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Imperial IFS40 Deep Fryer
Can i fill it with water instead of oil to see if it works? It is a used one and I wanted to make sure it works before waisting oil
You can to see if it just heats but not to see if it gets to temp. Water boils well below what the preset for oil for frying will be. You will literally boil your experiment out before you get there. That can fry electronics. Be CAREFUL.
Apr 09, 2010 | Philips HD6153 Deep Fryer
Why does the temp drop
thats easy its the law of energy and surface area you have a deep fryer that has large area of aluminum and aluminum conducts heat very well on the plus side it heats the oil quickly. on the down side it loses heat very quickly too so the machine is always turning on and off to balance the heat loss. when you place food into it that drops the temp also.
Dec 21, 2009 | Masterbuilt 20010406 Deep Fryer
Dean gas deep fryer m# SR142GN
Thermocouple is getting weak. Replace the thermocouple with a new part.
Apr 21, 2009 | Frymaster Dean 2424G Deep Fryer
Hobart deep fryer, light pilot heats to temp then all goes out?
You will need someone who is qualified in commercial gas appliance repair to fix this.
Liabilities would render this out of reach for anyone else.
Mar 29, 2009 | Hobart 1H50D Deep Fryer
Boiling grease
When the issue starts have you actually checked the grease temperature? You can also checkto see if there is excessive grease build up on the themostat.Sometimes uncooked food particles can cause a boiling type motion in the fryer while they cook. be sure to do regular filterings of the grease,this will cut down on the suspended particles.If the grease temp is above 350, shut power off and check continuity on the thermostat,it could be sticking closed,in which case it will need to be replaced
Mar 05, 2009 | Garland ED-30SFT Deep Fryer
Pilot will not stay lit on Imperial IFS75
I work with these vats in my business and it has been common in my experience that the pilot area needs to be cleaned. Take a paper clip or the like and clean the pilot area where the gas comes in. Make sure your gas line is not crimped. If you are handy, you may can take apart the orifice itself and clean it. Usually, I would say replace the thermopile. Make sure it is set close enough to the pilot so that it can heat up well enough to call for the gas.
Feb 15, 2009 | Imperial IFS75 Deep Fryer
Problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Nov 10, 2007 | Imperial IFS40 Deep Fryer
Wells F-686 Deep Fryer Logo
152 people viewed this question
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
Joseph Hoffmann
ray gallant
ray gallant
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
