Question about Dell Inspiron 6000 Notebook
Monitor is very dark
I have a dell inspiron 6000 lap top and my monitor is very dark, how do I correct this problem Thank You!
  • rebekaharm Sep 23, 2008
    I have an Inspiron 1420, a few days old, and the same thing is happening. I have the brightness all the way up but the display is still very dark. It was fine yesterday but dark today when I booted up. What's going on?
  • Dell Master
  • 5,569 Answers
I have to assume you have tried through existing means to change brightness and contrast.
These are generally provided for the user.
LCD screens are backlit via a fluorescent lamp. This is a high voltage device so the problem could come from either a failing lamp or the inverter circuit that drives it.
Access to the lamp varies greatly and to even check it may well be a job for a technician.
Posted on Mar 29, 2008
6ya staff
SOURCE:
I have a samsung synmaster 712 n monitor when and a dell inspiron computer lap top . when i plug monitor into lap top samsung light blinks and no signal on screen from lap top
Did you use the combination keys of your laptop Fn and either F5, 6, or 7 depends on brand to select internal/external/both? You also need to make sure that the video resolution feeding the monitor is at native resolution setting.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 15, 2010 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Dell Inspiron 1521 laptop monitor is dark.
It is a posible LCD problem, Might gone defective.
First trouble shooting is to turn off your laptop completele and the remove the battery and the charger and any accesories connected on yur lap top. Then press the power button for 1 minute. It will reset the settings of your laptop to default if you accidentally press the command for the hotkey to turn off the built in monitor and enabled the extended monitor.
If the issue persist it means it is an issue with the LCD and needs to be replaced.
Mar 28, 2010 | Dell Inspiron 1521 Notebook
My monitor picture is very dim after my son
Reloading or updating the graphics drivers might help.
Feb 24, 2010 | Dell Inspiron 6000 Notebook
I have a dell inspiron 6000 lap top I cannot
Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
Just make sure you have saved all your data before doing that.
Oct 29, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 screen splitting
This is a generic problem in most of Dell Laptops ( mostly inspiron ). It is caused due to a fatal fault or breakage in the Hinge Assembly. You need a new Hinge Assembly. Is it splitting more on decreasing the angle of the monitor. If yes, Hinge assembly is the only culprit. If you are under Warrenty then Dell will be liable for it and replace it free. If not under Warrenty, I approx. costs 300$. Thank you Sir, Have a nice day.
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Dark screen ,fn does not work
I would suggest connecting the laptop to an external monitor, just to make sure that it is all running correctly.
If you can see a very dim image on the screen then the backlight is out. This can be a light problem or the inverter that powers the backlight could be bad. The inverter is not real dificult to change and also is not very expensive. If it is the backlight tho, it is easier to just change out the entire screen.
Hope this helps
May 02, 2009 | Dell Inspiron 6000 Notebook
MY Dell Inspiron 8600 all of a sudden the LCD only comes up white
There will be a function switch to select the view mode ( Lap top monitor only/ LCD only / Lap top monitor and LCD Monitor) Select either the last two.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 08, 2009 | Dell Inspiron 8600 Notebook
The monitor in my computer turns dark when i turn the laptop on
That sounds like you have something loose ..
Here is an on-line service manual for that
I would look specifically @ the LCD/monitor lead and its connections
Jan 01, 2009 | Dell Inspiron 6400 Notebook
The make and model do not matter. Your backlight is going and will have to be replaced. A good computer shop will be able to do it.
Dec 23, 2008 | Dell Inspiron 6000 Notebook
Want to have dual monitor feature in my dell laptop
You will have to check and make sure that your video graphics hardware will support the dual option. If not, you will have to purchase a PCMCIA video graphics adapter that supports a second monitor.
Dec 04, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
184 people viewed this question
Ekse
Clive
Clive
Alun Cox
