Power Problem When I try to turn the TV on it starts to come on and then automaticely turns off. Please help.
1987 ford f250 300 inline 6 automatice. new starter battery and sylanode. negative battery terminal smokes when try too start. starter does not turn
Bad or dirty grounding point. Should have negative cable attached to engine AND body of car. Ensure both post at battery tight.
Aug 21, 2017 | Ford Cars & Trucks
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
Can not turn on the TV. Light blinks 10 times, then turn out and starts again blinking 10 times. I tried to plug the TV out but the same happens again!!! Can anybody please help me!
The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
My samsung tv won't turn on , It just started to
Your Samsung LCD TV needs a new power supply. You can obtain one by part number from sites such as shopjimmy.com, discount-merchant.com or tristatemodule.com.
Apr 26, 2010 | Samsung LN46A650 46 in. LCD HDTV
TV doesn't turn on
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
Nov 27, 2007 | Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Why won't my tv turn on?
Could be a hellotuv things, starting with the power supply. You could unplug it for the night(pull the plug out), and try in the morning, but if you want a more in depth answer you should include a bit more detail if possible. Such as, how did it start, is the standby light on, do you hear any noises/see anything from the TV when trying to turn it on, does the TV have any repair history, did you have a recent power outtage etc'. Post back and we'll do our very best ;]
Jun 09, 2006 | Philips Magnavox MT2501C 25" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
