Question about Fisher Paykel Eco IWL16
My f & P excellence 7.5 has a recurring problem. It tries to fill up, but in short bursts it stops and starts trying to fill and then gives up and beeps every second. It has done this befoe and I have been able to switch it off at the power point for some time and eventually, sometimes after minutes, sometimes after days, it has come good. But this time it just wont seem to work. I have tried to get it to spin, but it stops as i has the same problem with flushing in the water. the outlet taps are definiely on. I have also tried filling it with water manually, but it will not wash.
  • 343 Answers
Water spurting is not uncommon and can mean a cold inlet valve is faulty, however if you've filled the machine independently, with the water level set to 'low', and it won't work it could be the out of balance switch. This is situated below the motor control board. It's an awkward job for a user, but not for an experienced tech...Not an expensive fix....Good luck....Nomess
Posted on May 14, 2010
Stops and starts filling in short bursts then stops all together by beeping with the first and last light remain on how can I fix this ?
some machine use this filling process as a means of achieving a complete balance of clothes for the cycle
check that the program is not on long soak before it starts to wash
If you have everything as per the manual then call the technician as there may be a problem in the board
Jun 30, 2015 | Washing Machines
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Natural gas heater with auto (electric) ignite... The exhaust fan is coming on when the unit is turned on, but it is failing to ignite. I can hear it trying to ignite several times, then it stops. Is...
First make sure your gas is on. If that's not it make sure the pilot tube itself is cleaned out try tapping on the pilot head to remove any build up. The furnace on a call for heat will first start the combustion blower then start the ignition procedure, that first starts the spark igniter or glow plug then timed through the circuit board a short 3 second burst of gas after the 3 second burst if the flame sensor does not sense the flame a short purge cycle runs another 3 second burst of gas and then try's for ignition again. Knowing this the only thing it could be is a gas related problem either no gas or no gas making it to the pilot head or the gas valve itself is not opening so check the gas and the pilot tube if there fine then you're more than likely looking at a new gas valve. Sometimes tapping on the gas valve will free a stuck valve.
Hope this helps and please remember to grade me.......thanks again
Nov 24, 2010 | Heating & Cooling
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a kelvinator excellence 6.5 smartdrive9 top loader.The 3rd led,shortwash led,spin led and the one before the spin led is on and beeping. The machine will not fill and pulses in short bursts then...
your machine is a fisher and paykel, just re-badged. now the fault you have is your " OUT OF BALANCE" switch is faulty, probably due to corrosion . the switch is located under the control module which is under your display panel. if you choose i can guide you thru the repair. please reply 4 further help
May 29, 2010 | Washing Machines
F&P Smartdrive 058 filling in short bursts then stopping.
I had the same problem today. shephonos 18 had the correct diagnosis. Out of balance micro switch seized. Situated under the main circuit board. Cherry electric Corp 0.1amp 125 volt sptd type switch. jaycar has them for under $4.
I un-seized it with some electrical cleaning spray, fixed itshort term, no worries.
Thanks Stephanos 18.
May 04, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Eco IWL16 Logo
151 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
