Question about Maytag MDE16CS Electric Dryer
Control board maytag ldg23cd part number 30626
How can I reprogram my maytag fridge ?model number mf12269vem10
Did you change a control board and need to reprogram the controls because you installed a different control board or are you talking about changing the settings?
Jan 22, 2016 | Maytag Refrigerators
Why is my Maytag Epicz model #MGDZ600TW2 not starting and giving me an error code F01. What does it mean?
The F01 error code is typically a communication fault. You may have a defective main control board. Unplug the dryer or turn off the breaker to the dryer. Double check to make sure dryer has no power. Remove the screws holding the top on at the back of the dryer. Standing in front of the dryer push down and slide the top away from you then lift. With the top removed you will see a metal bracket on the left side housing a control board. Remove the control board from the bracket. You may want to take a picture to reference where the wires go. Remove the white cover of the control board then gently remove the control board from the white housing by pressing in the small tabs. If you see a black mark on the back side of the control board and the white housing replace that control board. According to your model number the main control board is part number W10111606.
Jan 29, 2015 | Maytag Dryers
Display does not light up at all
If the 120VAC wahser service outlet has power and the machine LED Control Console for the FAV6800AW or LCD screen for the FAV9800AW appeares to have no power then I feel you have a Control Board failure. If you post your model number we can give you and aproxmate cost of the Control Board. The Control Board is under warranty for 5 yr. If you call Maytag customer service at 1-800-688-9900 they will need your Model Number and Serial number located on the rear top right of the console.
The above machine types do not have an internal fuse or circuit breaker to check.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How do I get my Maytag Neptune TL washer to stop beeping and start washing again ?
Try disconnecting the 120VAC power cord for a few minutes then re-power back up if you haven?t already tried that. If you still have the same issue then you may have a failed Control Board. If it?s the FAV6800AW is there an error code in the LED display? If the machine will not d let you into Service Mode then my next step would be to replace the Control Board a 10 minute job. If you decide to call in a service repair company I would call Maytag for an authorized Maytag repair service in your area. Some parts like the Control Board may still be under warranty (5yr). Warranty info is in the SM link I attached. The number to call is 800-688-9900. Maytag will need your model number and serial number, that info is located on the back right top side of the console. The Service Manual for reference. Sears Parts Direct for reference. Post back if you have questions or want to dig deeper into the issue
Oct 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wont start just beeps and changes cycles
This could be a Control Board failure and this where I would start. I would try to recycle 120VAC power to the washer and see if that will restore operation. If that doesn’t clear the issue then I believe your Control Board has failed. Do you have surge protection at the washer 120VAC outlet? Have you had any recent electrical storm activity? The Service Manual can be found on this site follow the link I’m attaching. The Control Board is under warranty for 5 yrs from date of purchase. I got Maytag to send me a Control Board, I passed their owner technical savvy test. If you are the original owner, call Maytag customer service at 1-800-462-9824 www.maytag.com. They will ask you for your serial number that is found on the top right back side of the console. They will give you a number to call for authorized Maytag repair. I would insist that the repair service to bring out a Control Board on the first visit. The part number 25001217 for all FAV6800AW series. If your machine is a FAV9800AW LCD display flavor different part number
Sears Parts Direct see item 23
If you want to continue diy let me know….. Rich
Oct 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Start/pause button flashing and will not start or lock, also spin lights are out. What should be done?
Hello goss4
This could be a Control Board failure and this where I would start. I would try to recycle 120VAC power to the washer and see if that will restore operation. If that doesn’t clear the issue then I believe your Control Board has failed. Do you have surge protection at the washer 120VAC outlet? Have you had any recent electrical storm activity? The Service Manual can be found on this site follow the link I’m attaching. The Control Board is under warranty for 5 yrs from date of purchase. I got Maytag to send me a Control Board, I passed their owner technical savvy test. If you are the original owner, call Maytag customer service at 1-800-462-9824 www.maytag.com. They will ask you for your serial number that is found on the top right back side of the console. They will give you a number to call for authorized Maytag repair. I would insist that the repair service bring out a Control Board on the first visit. The p/n 25001217 for all FAV6800AW series.
If you want to diy let me know.
Oct 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Does anyone have the schematic for LCD control
Tom,
I don’t believe you will find a schematic for the control board. I have a FAV6800AW all I have be able to find is the wiring schematic found in the FAV6800AW/FAV9800AW Service Manual.
Is your machine out of the 5yr warranty period for the Control Board? I got Maytag to send me one.
Saw this on e-bay
NEW - Maytag Washer LCD Control # 25001189
Good luck … Rich
Oct 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Need mother board for maytag dryer model ldg23cd can not find one
I have about 20 of these boards in working condition. If you need one, let me know.
Coin Operated Double Stack Dryers - LDG23CD Dryer Board 3-6236 (or possibly 3-6443 or 9-12086)
Board - This part has been discontinued by the manufacturer and is no longer available.
Touch Pad AP4037678
Part Number: AP276590
Manufacturer's Number: 306236 (3-6236)
May 27, 2009 | Maytag MDE16CS Electric Dryer
Maytag MDE16CS Electric Dryer Logo
65 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
