Question about Balboa Instruments Duplex Digital Panel 2 Pump
Just installed new heater - error code sns - sensor out of balance- anyway to fix - balboa 2000m7
    Habit-Forming:
  • 77 Answers
Assuming that there are no air-locks and the pump is running ok....
Check the sensor connections on the PCB and make sure that they're clean and secure.
If the fault persists, (with the power turned off) you will need to remove the sensor connections and test the resistance of the sensors with an ohm meter. They should read the same. If they're different you will need to replace them.
Regards,
Ian.
http://hottub.synthasite.com
Posted on May 22, 2010
Getting a sns code on control panel display. Where is the sensor located on this pool heater?
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
Apr 25, 2015 | Rheem M266A 266K BTU Pool or Spa Natural...
Error code "OHH" displayed when
OHH code means "Overheat" condition
The spa has shut down -one of the sensors has detected 118 ° at the heater. Check it and replace it if go to bad.
Hope helps.
May 25, 2011 | Balboa Instruments Duplex Digital Panel 2...
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
1. Water temp is below 36 degrees F
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
The LED displays the letters 'dr' flashing & 'SnS' flashing what does this mean because my spa is full but will not heat.Also when the electrician came to power up the spa he's just ran it off a...
First, get a new electrician. Circuit should be a dedicated one, GFCI protected.
Next, the dr means the heater doesn't have sufficient water in it. The SnS means the sensor is out of balance. If the SnS is blinking, it just means the spa is shut down, more than likely because of the dr message...Check all your valving to make sure the heater is not isolated..
Jul 11, 2010 | Pool & Spa
Heater displays SNS - sensor failure. what do i do?
sns occurs when sensor reads temps under 36 degrees or above 110 degrees. check temp of of water to verify.....may need a new water sensor
May 30, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
I have the Balboa 500Z pump heater kit. Its hooked direct to a mighty iron ( 120v) recirclulating pump. Ever since it was new, I keep getting lack of water vflow errors ( dr, then dy ) I have plenty of...
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Dec 06, 2009 | Balboa Instruments Duplex Digital Panel 2...
When I put power to my unit. A Sn code appears. Great Lakes spa 1996 260E balboa wiring
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Dec 06, 2009 | Balboa Instruments Garden
My raypak heater is not working I have power but the screen is showing an error message SNS. What do I look for what sensor is not working.
Here is the link for the manual for your boiler.
http://www.raypak.com/uploads/6000.59R.pdf
SNS Sensor failure, Water temp. below 36°F
or above 110°F - The water temperature sensor has failed or a wire is broken. (page 35)
Jul 16, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
1,258 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
